steering help
Old Dec 27, 2010 | 07:20 AM
FLN's Avatar
FLN
steering help
I want to mount a steering stabilizer to steady this thing up at higher speed.My question is, did stabilizers come on these strucks factory and if so how do they mount up? If not still how do they mount? im sure one end has to go to the drag link but looking at pictures of these things and all bracket hardware its hard for me to tell.Any help appreciated.Also a good place to buy one. Thanks.
Old Dec 27, 2010 | 11:03 AM
crazed87bronco's Avatar
crazed87bronco
not sure if you have a 2wd or 4wd but check out this thread for pics if you have a 4wd
Old Dec 27, 2010 | 01:10 PM
FLN's Avatar
FLN
its a 2 wheel drive.
Old Dec 27, 2010 | 03:10 PM
CougarJohn's Avatar
CougarJohn
Are you sure that your problem is not caused by bad steering knuckles, links and king pins? Let uas know if you have not checked these things. We will tell you how.
Old Dec 27, 2010 | 08:28 PM
FLN's Avatar
FLN
new kingpins. Steering knucklesim not sure what your talking about.
Old Dec 27, 2010 | 09:03 PM
CougarJohn's Avatar
CougarJohn
Crawl under the front of the vehicle and look up at the tie rod ends, idler arm, drag link... everything that is connected to the steering. Have someone sit inside and wiggle the steering wheel back and forth and look for slop in any of the connections.
Old Dec 27, 2010 | 09:14 PM
FLN's Avatar
FLN
will do! thanks
TC-Countryboy
Sep 20, 2017 09:52 PM
Amicus
Jan 4, 2017 03:46 PM
cgi2099
Jan 31, 2012 08:55 PM
cgi2099
Jan 10, 2012 04:59 PM
cliwel
Jun 13, 2011 10:21 PM
