View Poll Results: MPGs in your Ford
Less then 5
2.94%
Less then 10 more then 5
17.65%
10 but less then 15
50.00%
15 but less then 20
20.59%
20
8.82%
25+
0%
Voters: 34. You may not vote on this poll
MPG Poll
Old Dec 27, 2010 | 12:52 AM
glovemeister's Avatar
glovemeister
MPG Poll
I just want to get a rough idea of what your mpgs are in your truck. Post up your truck specs engine size,weight, performance mods, tires, lift, etc. and your mpgs, and also vote on the poll please.
Old Dec 27, 2010 | 01:03 AM
panman65's Avatar
panman65
1982 302 c-6 33x15.5x15 super swampers 2in lift in rear 4 in front
Old Dec 27, 2010 | 01:23 AM
dooger's Avatar
dooger
1985 4x4 6.9 diesel fitted with 7.3 turbo auto trans no lift long bed standard cab 33x12.5x16 remington wide brute
Old Dec 27, 2010 | 07:35 AM
Diesel_Brad's Avatar
Diesel_Brad
80 F350 429 c6 4:10 35" swampers reg cab long bed 9mpg
86 F250 6.9 4spd 3:55 35s" radials reg cab long bed 14-17mpg
Old Dec 27, 2010 | 11:25 AM
newrider3's Avatar
newrider3
Bone stock F100/300I6/T18 except the engine mods listed in my sig, should be getting at least 20 according to others in the Inlines forum, only getting 11mpg.
Old Dec 27, 2010 | 11:55 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Bone stock, 1981 F-150, 300-6, T-18, 2.75 gears, 225-75R-15 tires.
21 mpg highway at 55mph. 17.5 mph highway at 65mph, average.
Old Dec 27, 2010 | 03:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Lightly built 460. Stock 235/85 R 16's, the rest is in my sig.
I'm on the fence with my new ZF.
It probably gets better highway mileage now but around town it's still 7-8.
If I see 12-13 highway I'll be ecstatic.
Old Dec 27, 2010 | 04:37 PM
ri_truck_guy's Avatar
ri_truck_guy
A consistent 15 mpg average with a 302 EFI roller H.O. from a 95 Stang, stock truck intake, Mass Air conversion with 91 A9P calibration computer, 3:55s, stock AOD, 32X11.5 15s, and a very heavy right foot....
Old Dec 27, 2010 | 07:19 PM
dyingtolive's Avatar
dyingtolive
About 16-20 MPG. Not 100% accurate, I haven't crunched any numbers or done any serious tests, but by watching the fuel gauge vs. the odometer, I got a pretty good idea of what I was getting, I think.
1984 F150, 300 I6, .30 Overbore, DSII Conversion, All emissions equipment and EEC computer removed, 31x10.50x15 tires, 4 speed transmission, 4x4, not sure what gears or rear end I have though.
Old Dec 27, 2010 | 07:28 PM
Shark Racer's Avatar
Shark Racer
If I do 70% freeway hauling I usually get 10-11.
Less than that 8-9.
83 F-250, 460, T-19, 3.55s, 31.5" tires and a front end lift. RC LB
Old Dec 27, 2010 | 07:30 PM
Freaksh0w's Avatar
Freaksh0w
1986 Ford F150 XLT Lariat 4x4 5.0 EFI
31x10.50 tires. Single cab swb
Np435, Ford 9" rear 3.50
Vehicle weight with me in it 5150lbs and little to no fuel.
Highway mileage 55mph @ 2300RPM nets 16mpg
City and backroad nets around 14 to alnost 15 mpg
With a 2200 pound load of oak I get more around 10 to 11 mpg highway and still more like 12 to 13mpg on the cruising backroads. Its a lot to do with my gearing. 1st through 3rd can pull anything easy on gas but the 1:1 4th requires more throttle with a load.
Old Dec 27, 2010 | 08:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I need to pull the plastic gear out of my old T-case.
Obviously my speedometer/odometer is off since my drivetrain switch.
There's no way I am traveling as fast as it says. The truck I pulled it from must have had 3.55's
Old Dec 27, 2010 | 09:46 PM
Shark Racer
Originally Posted by ArdWrknTrk
I need to pull the plastic out of my old T-case.
If you have or know someone who has a BlackBerry smart phone, you can use an app called "BlackBerry Traffic" to show your speed via GPS. Close enough to validate.
Other GPS devices should be able to do so as well.
Old Dec 27, 2010 | 10:00 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My iPhone has a similar app.
I KNOW I should not be getting passed by almost every car while indicating 75 mph.
Obviously an oversight when swapping transfer cases.
Old Dec 27, 2010 | 10:46 PM
Shark Racer
For fast convert, multiply by 0.86. 75 indicated ~= 65 actual, if you're going from 4.10 - > 3.55
One of my cars has 3.07s installed and the speedometer is set for 3.54s... that's a worse problem, and resulted in a ticket a couple weeks ago.
