Driving with hubs locked in?
To my understanding no it is not as most other 4 wheel drive rigs drive with the front axle locked and spinning anyhow without the transfer case engaged all year round.
I do the same thing except during the summer months.
During the winter months I lock in the hubs if I suspect I may need them and drive around with the front axle spinning but the transfer case not engaged. I have yet to see any ill effects.
I talked to a drive line guy, he's a bit of a gear head and he said that there is nothing wrong with it.
I also informed him that I will typically do it a couple times during the summer and before the snow flies to get the fluids mixed up and get the gears all lubed up.
He stated that it's probably not a bad idea to mix it up a bit fore use so that all the gear and bearings can get some fresh fluid before putting a load on them though it shouldn't hurt anything.
Wont hurt a thing driving around with the hubs in and the t-case in 2wd. We do it all the time up here snowmobiling. Then if we need 4x4 just pull the t-case lever into high range and go. I usually turn my hubs in 2x a month all year long and drive down my long straight road and turn the hubs out before I turn around and head for home just so the front end doesnt bind up during the u-turn on dry pavement. But on snow or gravel or anything where the front end can slip a little when you turn not a problem. Sounds like you guys on the other side are getting pounded with snow. Wish we had that problem over here right now.
I only lock mine in when the snows on the ground other than that the hubs are locked out, fuel economy reasons and less wear I've always thought. I do engauge them periodocly to keep the juices flowing so to speak. I believe HKUSP Jason keeps his locked in all the time but not 100% sure..He'll pop in I'm sure to confirm.
