I found this sight trying to find the problem with my 2005 Exedition.
I might add that we bought this used and don't know the history. It hasn't been wrecked that we can tell or see. Clean car fax for what it's worth.
I have had it to the Alignment shop twice and this thing keep wearing the Right front outside tire off. They say nothing is loose and needing replaced. I might add that it has factory air ride. Is there anything that needs to be looked at that they are missing. It's only wearing the Right front tire and it's only the outside. It will wear out a tire in 20,000 if you don't keep it rotated.
Its a toe problem. Chances are the shop you are going to does not have very updated equipment. These trucks benefit from a 4 wheel laser alignment machine but only shops with a lot of money get them. I had been through the same issue with my 2003 and finally went to a different shop.Most Les Schawb tire centers have them and so do some Firestone.
