Spark Plug Wire Crossfire?
Old Dec 16, 2019 | 07:24 PM
Eddiec1564's Avatar
Eddiec1564
The old photo was lost when FTE did a site upgrade. 6 years ago that wore out 302 died and I put in a fresh rebuilt I6 300 engine(with its share of issues)
Old Dec 17, 2019 | 07:34 PM
Maillemaker's Avatar
Maillemaker
I was not able to pull the doghouse tonight and confirm where they ended up, but it is clear from the distributor and the direction that the wires are going that it does not match the above diagram, if I'm looking at it right.
Old Dec 17, 2019 | 07:37 PM
Maillemaker
I think this diagram matches mine.
https://www.ford-trucks.com/forums/1...e-routing.html
Steve
Old Dec 18, 2019 | 08:11 AM
rla2005's Avatar
rla2005
Both diagrams (the one I posted in this thread and the other) show the same firing order. The diagram in this thread shows how to route the wires to prevent cross fire. Most distributor caps have a terminal labeled for Cylinder #1. Does yours? If so, is Cylinder #1 plug wire installed there?
Old Dec 18, 2019 | 04:18 PM
Maillemaker
I'll have to wait until after Christmas till I can get the RV back to the house and pull the doghouse and re-route the wires. When they replaced the distributor/wires/plugs I had already confirmed that they were running to the correct plugs. But I'll go over it with a fine-toothed comb later. I know right now the wires are running under brackets and close to other metal things. I will neaten them up and use the wire separators I bought.
Steve
Old Apr 19, 2020 | 11:09 AM
wingnover's Avatar
wingnover
3rd Gear
Steve
I'm dealing with a wire routing puzzle after reworking the heads,did you have any luck with wire route. Mines a 97 Dolphin f53 7.5 efi Thanks
Old Apr 19, 2020 | 12:37 PM
Maillemaker
At this point I have replaced every electrical item on the motor. I have also replaced both fuel pumps and the fuel filter, and cleaned all the injectors. I still have a barely perceptible "stumble" sensation around 45 MPH when I am lugging the engine. The current theory is that this is the torque converter lockup slipping. I've been running Top Tier detergent gasoline through it lately.
Steve
Old Apr 19, 2020 | 03:36 PM
torq'ta 5 8's Avatar
torq'ta 5 8
7.5L/460, routing
Ddaybc
36
Sep 5, 2015 08:05 PM
Buckethead1974
1997 - 2003 F150
Apr 19, 2010 08:17 AM
cbass139
Jul 21, 2009 11:16 AM
Southernguy101
Feb 26, 2005 08:26 AM
Scout
May 25, 2004 09:19 PM
