gas gauge
Old Dec 25, 2010 | 09:19 PM
arrowheadfred's Avatar
arrowheadfred
gas gauge
I was showing off my truck 2day and my gas gauge won't working. Its all new from the tank to the dash. I only put 4 gals. in it a few weeks back to fire it up for the frist time. Maybe it just don't have enough to register ?
Old Dec 26, 2010 | 12:21 AM
BlueOvalRage's Avatar
BlueOvalRage
Stock gauge or aftermarket? And yes, 4 gallons is borderline for being enough to register.
Old Dec 26, 2010 | 12:34 AM
arrowheadfred
gauges
There aftermarket blue man. I'm going to fill it up monday and see what i got.
Old Dec 26, 2010 | 07:36 AM
sdetweil's Avatar
sdetweil
also, check the ground at the tank..
sam
Old Dec 26, 2010 | 08:24 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you still have four gallons in it, it should register about 1/4 full since the tank is a 16 gallon tank. You may need to bend the float arm down a little to get a more accurate reading...
Old Dec 26, 2010 | 09:03 AM
BACAGrizz's Avatar
BACAGrizz
I know this is probably a stupid question but, did you test the sending unit and gauge before you put it in the truck?
Old Dec 26, 2010 | 11:44 AM
arrowheadfred
tank
sam
Gound what ground It has one wire going to it. thought it gounded to the cab. ???????
Old Dec 26, 2010 | 08:09 PM
GreatNorthWoods
You can't have too many grounds. Even though the tank is grounded to the cab it may not be a great ground. It's best to run a separate one. You can usually run a ground wire from one of the sending unit retaining screws to the cab or other place for a better ground...
