Ignition Coil Testing
Old Mar 4, 2003 | 08:36 PM
Joey1986Z's Avatar
Joey1986Z
Can this be done with a multimeter?
What is acceptable?
The truck runs good cold, but 'misses' at operating temperatureat crusing speed, doesn't idle well, but runs fine at WOT.
1971 302.
Thanks!
Old Mar 4, 2003 | 10:45 PM
Mil1ion's Avatar
Mil1ion
Here you go.
Measure away!
http://www.fluke.com/application_not...AGID=1&SID=103
Old Mar 4, 2003 | 10:50 PM
Mike W's Avatar
Mike W
If you are good at high speed, the coil is probably ok. Some testers used to heat up the coil to test it. I have seen very few bad coils.
Old Mar 5, 2003 | 12:32 AM
BB's Avatar
BB
Coil specs. @ 75* F
Primary Resistance 1.4 - 1.54 ohms
Secondary Resistance 7600 - 8800 ohms
Old Mar 5, 2003 | 06:38 PM
Joey1986Z's Avatar
Joey1986Z
Thanks everybody!
Here's what I got.
Forgive me I don't know which is primary and secondary.
Large Terminal that goes to distributor connected to either of the two smaller identical terminal I got 9.03 Ohms at Operating temperature and 8.54 Ohms when the truck was cool enough to remove the coil from the manifold.
The two smaller terminal connected I got 0.00 Ohms both temperatures and all ranges on the multimeter.
I have a cheap Sears multimeter. I'm taking the coil to work and let one of the electrician check it. If their Fluke confirms my readings is it time to replace the coil?
Thanks Again,
Joey
Old Mar 5, 2003 | 11:22 PM
Joey1986Z's Avatar
Joey1986Z
I return with my tail between my legs!
I guess I'm really getting 9090 Ohms(on a 20K scale).
I moved the scale down on the 0.00 and am now getting 2.2 Ohms.
Nevertheless am I out of spec?
Old Mar 5, 2003 | 11:51 PM
BB's Avatar
BB
I think you're ok, there are a lot of variables in taking resistance measurements anyway.
barry
mattymax
Mar 10, 2017 01:39 PM
raerjim
Sep 30, 2016 05:58 AM
catch44
Apr 14, 2016 05:34 AM
GORDEN1234
2015 - 2020 F150
Feb 12, 2016 02:22 PM
lightninquick
2009 - 2014 F150
Feb 21, 2012 09:04 AM
