Edel heads
Old Mar 10, 2003 | 01:00 PM
proeliator's Avatar
proeliator
Edel heads
Actually, I prefer the iron heads myself. I specifically asked Dennis about how his flow compared to the eboks and he said (I may be getting this backwards...old memory isn't what it was) that with a good port effort his would flow the same on the intake side and a little more on the exhaust than the eboks. Since he sets these up you'd just have to tell him what you wanted. The only caveat was, that if you took the eboks and ported the snot out of them then they would flow more than his in both cases. I don't build high enough compression engines to take real advantage of the aluminum anymore, what with gas being the crap it is these days. I think they are both good options, I just prefer the durability of iron in an application where weight isn't much of a factor. That, and since I have already had problems with Ebok machine work quality control I'm sure I wouldn't be as lucky as Rat and I'd have heli-coils popping out like jack in the boxs.
fordaholic-67F100
15
Mar 11, 2005 07:36 PM
Randyb12
Aug 20, 2004 11:43 AM
TheImpaler
19
Jun 8, 2004 05:27 PM
fe8u
Jun 28, 2003 09:54 PM
stephenw
May 10, 2002 11:06 PM
