Ersons/Valve Covers
Old Jun 2, 2004 | 09:50 PM
TheImpaler's Avatar
TheImpaler
Ersons/Valve Covers
Will the tall Edelbrock Signature series valve covers clear Ersons on Edel. heads?
-Patrick
Old Jun 3, 2004 | 07:38 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Pat that what Greg was running on his 446..before he changed over to the fabricated
rocker covers..and he said they worked fine with no issues...he runs erson rollers!
Russ
Old Jun 7, 2004 | 04:29 PM
TheImpaler's Avatar
TheImpaler
Bah - just as I had feared, they don't fit. I called Jegs, Summit, and a few of the local places in search of a tall version of the Edelbrock. I came up blank on all acounts. "What the heck," I said, "I'll order the Edelbrocks."
Long story short - they're here and they do not fit. It is mostly the PCV baffling that is causing me problems.
How do I proceed, oh wise ones? Can I cut that baffle out and pretend I don't have a PCV? Can I order some new, relatively inexpensive valve covers?
...Help me! Eeeeeek!
-Patrick
Old Jun 7, 2004 | 04:54 PM
gtex's Avatar
gtex
They worked for me.
I had the cheap Edelbrock stamped steel signature series.
Old Jun 7, 2004 | 04:56 PM
RapidRuss's Avatar
RapidRuss
Pat Im so damn sorry..I never asked Greg if his had the baffle in them?
Ya want to have a baffle in them to keep all the oil where it belongs and not on top of the motor..I asked Greg about his..and he said they cleared..I guess his dint have the baffle in them...
I feel bad now...I shouldnt give out info..unless I know first hand..Maybe you can Exchange them...If there's a restocking fee..let me know..I'll pay for it!!
I feel bad!! Russ
Old Jun 7, 2004 | 05:01 PM
TheImpaler's Avatar
TheImpaler
No no no! Your informatin was not the culprit, rather, it was my "what the hell" approach. A minor setback at best, this is not really a concern right now. I still have to mount my gas tank and get my shifter in before the truck can move. Not to mention getting motor mount nuts, fabbing up a plate to cover the firewall ( I always hated that damn heater box...not a concern any more!), mount my alt, get the PS stuff back in there, and then get that darn front clip assembled. Needless to say, the covers aren't going to be a delay.
Alas - back to my MegaShifter install. (The truck won't go fast, but it'll look like it does. *giggle* )
-Patrick
Old Jun 7, 2004 | 05:04 PM
RapidRuss's Avatar
RapidRuss
Well Pat..I just hate giving BS info!! I try..but im old!! LOL!!
Did you get the truck Mega shifter?
Old Jun 7, 2004 | 05:19 PM
gtex's Avatar
gtex
I'm pretty sure mine have baffles as well. maybe I'll take some pics when I get home to make sure we are talking about the same covers.
Old Jun 7, 2004 | 05:23 PM
RapidRuss's Avatar
RapidRuss
Greg..I tought you said they did? but Im not sure? cause I wanted to buy your off you..til I had they money for Cobra's or the fabricated one's??
Oh well...Ya never gave me price either..I think your Dodging me?? LOL!! Russ
Old Jun 7, 2004 | 05:27 PM
RapidRuss's Avatar
RapidRuss
Im not firmiliar whit the bottom side of those covers ?? he may need to cut the nipple on the PCV valve for clearence?? im just guessing?
TheImpaler's Avatar
TheImpaler
Yep - it's the truck one. So far, it looks about right as far as craftsmanship and install; a nice piece in my opinion.
We may be talking about different covers - I got the cheap signature series or whatever - ~$50.
They almost clear, but the shaft support/stand hits between the 3rd and 4th cylinders.
-Patrick
Old Jun 7, 2004 | 05:32 PM
RapidRuss's Avatar
RapidRuss
Pat those were the Tall sigs??
Old Jun 7, 2004 | 05:34 PM
RapidRuss's Avatar
RapidRuss
Well gregs going to be home in a bit and check his.....Ill check back...I have another arcre to mow!!!
Old Jun 7, 2004 | 05:35 PM
gtex's Avatar
gtex
Mine were like $50 as well. Mine weren't labeled as "Tall". I think the were the 4462 part number you can get at Summit etc. Are you trying it with the pushrods installed, holding the rockers in position. Maybe if you had a rocker sticking straight up it would be a problem.
I know I was running them for a while.
Russ, I'm pretty sure I sent you an email recently about the covers..
Old Jun 7, 2004 | 06:23 PM
Randyb12's Avatar
Randyb12
I have the Edel heads, Erson rockers and Edel Signature Valve covers. They touched. Just set them in place and give them a tap just above the baffle. If that doesn't do it then turn em over and "adjust" the baffle. you will see where the interference is by the witness mark.
