Sponsored by: Innova
another speaker install question..
Old Dec 25, 2010 | 08:51 AM
more d's Avatar
more d
I did try and look before posting but this awsome site has TONS of great info. i got 18 pages deep.
i have a '08 f250 sd. cc.
i want to install speaker in the factory locations, front doors and rear back panels, on my own after seeing what the local shop wants for it.
do the door panels come off by lifting up?
for back: do i have to remove the rear bench? better yet...has any one installed the speaker in the door pocket area? i dont use that space ever anyways.
thanks in advance for the info. i want to do it right because im going to keep this truck for ever GOD willing!
More D
Old Dec 26, 2010 | 03:59 AM
fz1dave's Avatar
fz1dave
Super Duty
For the front doors I think there are 2 screws along the bottom that need to be removed. Then there is a small 3" panel insert under the armrest that needs to come off, and the 2 screws behind that need to be removed. After that it should lift up and off. You might have to unplug the switches before it will come all the way out.
I'm not sure about the '08 rears, but this thread on a 2010 might have some helpful hints.
Old Dec 26, 2010 | 10:00 AM
more d's Avatar
more d
I did see that, great write up!
Ill start off with the front for now untill I find more info for the rear install. I just can't figure how to get the rear speaker with out removing the bench.
How about the color of the factory wires for neg. and pos.?
Thanks again for the response!
More D
Old Dec 26, 2010 | 10:28 AM
more d's Avatar
more d
i found this....hope it helps someone
2008 Ford F250 Stereo Wire Harness Color Codes
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Violet/Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Old Dec 26, 2010 | 03:54 PM
fz1dave's Avatar
fz1dave
Super Duty
Glad to see you found the wire codes.
The12Volt is a good source for info like that, and just about anything else mobile electronics related.
evan63
Dec 5, 2021 06:28 PM
sparks717
Apr 25, 2014 02:04 PM
comadvan
Apr 3, 2013 08:53 PM
rwjr
Oct 28, 2009 08:18 AM
James N. Gowan
1978 - 1996 Big Bronco
Apr 12, 2004 11:35 PM
