Computer Chips & Tuners
jet performance chip
Old Mar 4, 2003 | 08:15 PM
jsalza's Avatar
jsalza
I recently posted a message about cutting off my cat converters off my F-150(5.4l). I had a response about if it's legal. That's isn't my main concern. If I need a chip so my check engine won't go on, what chip do you recommend. I just purchased the jet performance chip on Monday. I realized that this particular chip doesn't have certain questions to answere when installing like the Diablo or the Hypertech power programmer. Can someone respond with their input. Secondly, If I do install the performance chip, will throw off anything in my engine that i might be concerned about.
Old Mar 4, 2003 | 10:36 PM
FTE Ken's Avatar
FTE Ken
The reason it doesn't need the ECU code is because of all the chips, its the worst. Its generically programmed and then only at wide open throttle. Its the only chip I'll outright say is junk.
Buy what we sell, buy what someone else sells.... just buy anything but Jet.
To keep the check engine light from coming on you'll need a custom programmed chip, which we can do either as a Superchips or a Diablo chip.
Bad1993
1978 - 1996 Big Bronco
Nov 23, 2016 09:52 PM
95F-150EddieBauer
Aug 13, 2013 01:13 PM
fender72
3.8 & 4.2L V6
Sep 7, 2009 05:43 PM
gthbryce
May 15, 2009 08:58 AM
bansheemike
16
May 27, 2005 01:53 PM
