1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Drain Water Separator???
Old 12-25-2010, 01:10 AM
ackeiyword's Avatar
ackeiyword
ackeiyword is offline
Ok I am sorry I know this have been covered extensively but I still have a few questions. I got the warning light the other day. This is the first F250 I have had so I tried to drain it and nothing came out. I took it in and got the oil changed, oil filters and fuel filters. Then the light came on again I tried to drain again and then it started just dripping. I don't know how long to let it drip so I left it for about 20 seconds, it never got to a steady stream. The light came back on. Should I let it drain until I see a steady stream? Is there anyway that I should clean this?
It is 09 6.4 with 45k miles on it.
Thanks
Old 12-25-2010, 05:48 AM
cliles55's Avatar
cliles55
cliles55 is offline
Try this link: click here. You might also try the diesel forum on this website. I hope this helps.
Old 12-25-2010, 06:24 AM
gearloose1's Avatar
gearloose1
gearloose1 is offline
Possibilities:
- sensor bad / need cleaning
- wax / gel as in above link
- ice
Open it up, clean it up, check sensor, then...
Put some anti-gel and water dispersant and cetane boost in your tank.
Old 12-25-2010, 07:55 AM
senix's Avatar
senix
senix is online now
Received 1,547 Likes on 1,103 Posts
Using the above link you can take that cover off to check inside. I may just be a sensor though.
Also...what about fuel? are you sure you have good fuel?
This picture shows the fuel/water separator in detail. Comparing that to the above link you can see it is easy to take the cover off and check it.
File Type: pdf
Old 12-25-2010, 09:13 PM
nitrogen's Avatar
nitrogen
nitrogen is offline
even just try pulling the plug and poke a wire through the hole and stir it around. as soon as you pull the plug it should gush out.
troverman
6.7L Power Stroke Diesel
19
12-02-2015 06:49 PM
Hunt4jesus
6.4L Power Stroke Diesel
01-21-2014 02:08 PM
jasonmilford
19
05-27-2012 06:24 PM
marspec
48
02-12-2012 11:05 AM
naseflorio
09-23-2009 12:45 AM
Quick Reply: Drain Water Separator???
