heater
Old Dec 24, 2010 | 07:59 PM
96stroker84's Avatar
96stroker84
heater
On my 96 7.3 my heater dosent work all the time will work one day but say the next two it wont. When it dosent work u can still feel heat comin out of the vent but wont blow out even on high it still dosent blow. Any ideas. Live in iowa so its a pretty cold ride. Thanks alot to any ideas. Merry christmas to all ford enthusiasts!
Old Dec 25, 2010 | 08:26 AM
RRranch's Avatar
RRranch
It doesn't blow on any speed? I'd look at your fuses first. Someone may have tapped into one for some accessory and it's loose now. Something is loose somewhere.
Old Dec 25, 2010 | 09:03 AM
96stroker84
Some days it will work just fine. Then other days ur right wont blow out on any setting. Fuses all seem fine. Will look further into the fuse Box. Thanks
Old Dec 25, 2010 | 09:26 AM
kawa's Avatar
kawa
Talking
Heater switch and the heater motor should be considered as suspect as well.
Rog
Old Dec 25, 2010 | 11:00 AM
makomark's Avatar
makomark
Sounds like an intermittent at one of the connectors.
Don't forget the fan resistor, too. They usually are the first item I check.
Brad9907
Electrical Systems/Wiring
May 29, 2019 04:36 PM
ALedbetter1
Dec 16, 2015 05:08 PM
Mike Parker
Oct 29, 2015 05:47 AM
sunny.richter
Oct 4, 2015 08:32 PM
dieself250
Jul 3, 2010 10:40 AM
