intake cleaning
Old Dec 24, 2010 | 04:07 PM
jakesfj40's Avatar
jakesfj40
intake cleaning
I'm doing a EGR delete and oil cooler replacement and when I'm in there I cleaned up the turbo whitch brings me to the first question hase any one brocken the bolt for the band clamp around the turbo? Can I replace the clamp or just the bolt?
Question 2. is there a safe (for the engine) way to clean the inside of the intake manifold? I have a parts washer but will the residue or left over cleaner mess up the motor or censers when I put it back together?
Thank you
Chris
Old Dec 24, 2010 | 04:13 PM
gearloose1's Avatar
gearloose1
The clamps are not your average clamps --- advise you march over to Ford to get a brand new set.
If you are going above factory boost, I would think of new hoses as well.
There are some posts on how to do the cleaning of the plenum properly --- search for them.
Old Dec 24, 2010 | 04:49 PM
wulfman's Avatar
wulfman
Hey fj40 i just finished what you are doing. Put my manifold in my parts for 3 days, took off some but not much. purple power from wallmart works better, or just have it hot tanked. good luck, Hey take your time with turbo plumbing its easy to get leaks. I have got to pull turbo back off , think i have crack in y pipe
Old Dec 24, 2010 | 08:33 PM
jakesfj40's Avatar
jakesfj40
ok i'll pick some up and let it soak. and take it to the car wash and high pressure wash it with some degreaser. I'm doing a EGR del. so there should not be any more carbon build up in the plenum.
Chris
Old Dec 24, 2010 | 10:25 PM
rocky1074's Avatar
rocky1074
The best thing to do is have it hot tanked!!!!
Old Dec 25, 2010 | 05:09 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX
yup
I took mine with me to the machine shop when I had my heads pressure tested. Find a shop that will hot tank it. The one I used I think even bead blasted it to get it spotless, all for $25!
Since you are doing the EGR delete it shouldn't gunk up again. You might as well have full flow through it.
Old Dec 25, 2010 | 08:14 AM
hubler13f's Avatar
hubler13f
I broke my turbo clamp last week while cleaning my turbo and just got it in on Wednesday. Heres a pic of the packaging and the part number. It comes with a new clamp and lock nut. Prepare your wallet though $62 for that thing.
Here's a link to my broken turbo clamp thread. https://www.ford-trucks.com/forums/1...ml#post9731331
Old Dec 26, 2010 | 08:28 PM
jakesfj40's Avatar
jakesfj40
thank you.
That's a little steep I'll check with the International mech. I've got some time to shop around.
Chris
Old Dec 26, 2010 | 08:31 PM
gearloose1's Avatar
gearloose1
I once had a turbo clamp blow off...
In a pinch, 2 garden variety hose clamps held (with a light foot) until I got it fixed.
Solomon_Man
Air Intakes, Air Filters & Ram Air
Oct 14, 2014 08:29 AM
landmobile
May 24, 2012 03:42 PM
Slickie123
Mar 29, 2012 01:30 PM
RubberDuck
Oct 31, 2006 08:48 AM
AustralianF250
Jul 13, 2003 08:06 PM
