My truck is running really good, there is no leaks and everything seems to be fine. I checked the coolant level on it the other day and it was really low. I checked to see if its leaking from anywhere but nothing. Anyone can tell me something??????
will do, ive been snow plowing and its been running for long periods at a time. it wants to get hot if i try to go too fast on the highway when the plow is on.
If they opened up the system, I am willing to bet you (5 chances out of 10) that the tech did not do the coolant flush properly and exactly to Ford spec.
Have a look on here as to how much effort / time / money, etc. it takes to do coolant flush properly.
That means doing cleaning with VC-9, bleeding air out completely.
Look on your bill, if it does not say they used VC-9, they did not do it right.
I would stick the Ford recommended coolant change / flush procedure in their nose, and make them do it right for free --- think it is normally a $200 or $300 service to do it right.
What you seem to have is air in system that worked its way out --- and not a leak.
Hence my instructions are to eliminate that first, before you start dropping big time and bucks on diagnostics and "fixes" that you may never need to begin with.
f250 2004
Just rememeber the proper cold-fill level is no higher than the minimum point. Lots of folks actually keep it at 1/4 inch below the lomin level mark. It is normal to see the level fluctuate in the degas bottle.
Aye.
The coolant capacity is 27.5 Q for the F, and a tad less for the Es.
Normal fluctuation seasonally measured by level change on the side of the degas bottle:
If you are going to do this right... might as well change out the thermostat, use brand new coolant hoses, etc. if your vehicle is over 6 years old and the stuff is original.
A combination of air in system purged out and normal expansion, and a bit of weeping loss (normal) would do it.
Unless you got coolant changed by a 6.0 guru / diesel tech who goes by the book, there is a high likelihood that the previous changer did not purge air out properly.
If I look at my degas bottle in my garage it reads one level.
If I read it out in my driveway... it reads a different level.
My point is... I swear that my garage and driveway are both level... but I know better... my driveway has slight slope to it which is very slight... but to an untrained eye (mine is trained) ... it looks level.
My point is... check your coolant level in your garage everytime to be consistent.
Yes... air worked its way out of the system... my son and I just changed his coolant and it takes 1 to 2 days for the air to purge out of the system after a few heating and cooling cycles and the thermostate opening and closing. The difference will be about an 1/2" in the degass bottle.
ford did coolant change, and fixed leaky egr. it hasnt really leaked though since then.
By leaky egr, do you mean egr cooler? If so then they should have replaced the oil cooler at the same time or you could still have the root cause of your original problem.
