Sponsored by: Auxito
K & N Filter mod
Old Dec 23, 2010 | 10:11 PM
f150_truck's Avatar
f150_truck
K & N Filter mod
I'm looking to buy a K & N Filter Kit for my 2001 4.2L and want to know if any of you guys have experience a change in horsepower or MPG, I have done some research in the internet and have not convince me since this are not cheap product.
Does this work for a smaller engine 4.2L?
Old Dec 23, 2010 | 11:30 PM
tofer76's Avatar
tofer76
i got mine for my 5.4 on ebay for 40 bucks shipped its not k&n but who cares even if i put a actual k &n filter element on it its still under half price
Old Dec 24, 2010 | 02:15 AM
Hybris's Avatar
Hybris
Never saw a MPG or Horsepower boost but I did note that my throttle response felt better and its nice not having to buy a new filter every 3 or 6 months.
Old Dec 24, 2010 | 02:18 AM
phil6608's Avatar
phil6608
Basically it's a wast of time and money. Not going to do anything but look pretty. Will not increase your power or mileage.
If your gonna do it anyway , get the cheep ebay one.
Old Dec 24, 2010 | 09:06 AM
KhanTyranitar's Avatar
KhanTyranitar
First off, before you even consider purchasing one, ask yourself, what is the purpose of an air filter. The purpose of an air filter is to remove any harmful particles that might otherwise get into the engine and cause damage over time. If this part does not improve either performance or mileage, is it worth the risk of engine damage. Are their filters out there that will protect the engine and is washable?
Ok, so lets start with this. This is a test of numerous air filters using industry standard test equipment, which interestingly enough, most performance filters prior to this were never tested on.
ISO 5011 Duramax Air Filter Test Report
AFE makes a performance filter, that while not shown on this test, was later tested at AFE's expense. The filter is known as the ProDryS because it uses a dry filter element (no oil). It is made from synthetic media, so it can be washed and reused repeatedly. According to the test AFE conducted, the filter is 99.8% efficient, flows up to 30% more airflow than a paper filter, and takes about as long as a paper filter to clog and become restrictive. Thats a lot better than K&N did on the same test. The K&N clogs faster, lets more dirt through, and becomes more restrictive than a paper filter very quickly.
I personally use the AFE ProDry filter and love it, its easy to clean, it cost less than a comparable K&N, and I like that it protects my engine like a paper filter.
Old Dec 24, 2010 | 09:23 AM
phil6608's Avatar
phil6608
Dose the AFE go right in the stock air box?
Old Dec 25, 2010 | 08:30 AM
KhanTyranitar
Mine does, they have cone filters too.
Old Dec 25, 2010 | 08:58 AM
phil6608's Avatar
phil6608
I always like the drop in filters. There usually less expensive then buying a hole kit and most times work better.
Old Dec 25, 2010 | 09:16 AM
steve(ill)'s Avatar
steve(ill)
all the after market filters do for you is lighten your wallet. Keep the factory filter and your money and do something worth while.
Old Dec 25, 2010 | 09:51 AM
galaxie641's Avatar
galaxie641
Technically they save you money in the long run. I haven't bought a throw away air filter in probably 8 years. Last time I did they were around $15, a K&N pays for itself pretty
quick in those regards. I ran a K&N for several years then got a AF1 FIPK.
Old Dec 26, 2010 | 12:25 PM
jayft8's Avatar
jayft8
Yes I definitely did,
BUT
that was paired with a performance exhaust system - I think I needed the both together to see the results I got
Old Dec 26, 2010 | 12:30 PM
jayft8's Avatar
jayft8
ps
For what it's worth to you - K&N really stands behind their product very well and if you take care of your filter properly they really will last you a lifetime. I have one that's almost 30 years old.
//mjeff
3.8 & 4.2L V6
34
Nov 20, 2011 09:57 PM
kyle.good
1997 - 2003 F150
Oct 25, 2009 02:46 PM
metalnova
3.8 & 4.2L V6
Sep 13, 2004 10:10 AM
//mjeff
1997 - 2003 F150
May 11, 2004 05:32 AM
davesmyth
1997 - 2003 F150
Oct 25, 2002 07:02 PM
