I HAVE A 1998 FORD EXPLORER, 4.0 DOHC, 108,000 MILES. TODAY WHILE DRIVING I HEARD A LOUD POP, AND THE MOTOR QUIT. IT WILL CRANKS OVER JUST FINE BUT HAS NO COMPRESSION TO START UP. I AM PRETTY SURE ITS THE TIMING CHAIN. I WOULD LIKE TO KNOW HOW MUCH OF A JOB TO FIX THIS AND THE PLACE TO GET PARTS FOR IT. SOME PICTURE OF THE R&R WOULD HELP.
same think happend to me with my 4.0 shoc, I just replaced the motor that was the best thing to do, looking at engine the passanger side timing chain is between the motor and trans, there is a jack shaft that goes thru the motor that spins that chain. so the only way to change that is to rip out the motor!
Do a search, there are some posts where the owner did the rear chain in the vehicle. I know it's not much help for a PITA job. I think pulling the engine would be easier. The later engines supposedly do not have this problem, around '04 and newer if you have to replace the engine.
