95' E250 Trans Temp. Sensor
Old Dec 23, 2010 | 03:42 PM
Stored Ford's Avatar
Stored Ford
Does anyone know where the trans. temp. sensor is located on a 95' 4.9 liter straight six with auto? (I'm getting a 636 code: Trans oil temp. higher or lower than expected.)
Thanks!
Old Dec 23, 2010 | 10:35 PM
Henry10s's Avatar
Henry10s
Which transmission do you have?
Old Dec 24, 2010 | 03:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's an E4OD. The temp sensor is on the solenoid body inside the pan.
Old Dec 24, 2010 | 07:13 AM
Henry10s's Avatar
Henry10s
The code means that either something is wrong with the wire harness, or something is wrong with the sensor itself, or that transm overheated or overheats.
Try to clean the contacts on the transmission harness (might not solve your problem). New fluid might help. I would erase the code. If the code persists, transmission /sensor needs to be checked.
Old Dec 24, 2010 | 09:20 AM
Stored Ford
Thanks Guys!
I knew this was a great resource when I found it. I appreciate the information!
Have a great Christmas!!
Stan
finallyo3gt
18
Jul 16, 2016 08:47 PM
LeoJr
Jul 7, 2016 07:36 AM
Whynotgman
1978 - 1996 Big Bronco
Jun 16, 2016 05:04 PM
86scotty
May 19, 2014 09:51 AM
86scotty
May 18, 2014 09:05 PM
