Factory driving lights?
Old Dec 23, 2010 | 03:35 PM
sandyc's Avatar
sandyc
I can't seem to get the driving lights working. I followed the instructions in the manual. I assumed I have this option, because of the Lariat package and all the other packages I got, maybe I'm wrong. Has anyone had this problem?
Sorry about the spelling: Factury vrs Factory. I'm an Aggie, what can I say
Old Dec 23, 2010 | 03:46 PM
rdenis's Avatar
rdenis
You talking about the fog lights? If so, you need to turn the switch clockwise all the way and then pull out.
Old Dec 23, 2010 | 03:50 PM
jermort's Avatar
jermort
Actually, the fog lights will come on with the switch in the first notch (parking lamp position).
Simply turn the **** to park, gently pull out 1/4".
The fogs only work if the headlights are on low beam.
jammer
Better question is: are you looking for Daytime Running Lights?? (headlights on at 1/2 power).
Old Dec 23, 2010 | 04:01 PM
sandyc's Avatar
sandyc
"Daytime Running Lights", headlights set at 1/2 power is what I meant. That's what I'm having trouble with. Sorry about the confusion.
Old Dec 23, 2010 | 04:05 PM
2011screw's Avatar
2011screw
Daytime running lights are standard for Canada. I am not sure if you can get them to go on. I think a dealer may need to do it for you.
Old Dec 23, 2010 | 04:14 PM
rickatic's Avatar
rickatic
that is my understanding as well...is the daytime running lights mandate what raises the Canadian price as high as I hear...
Old Dec 23, 2010 | 04:16 PM
sandyc's Avatar
sandyc
The owners manual tells you how to do it, but It won't work for me.
Old Dec 23, 2010 | 05:01 PM
rdenis's Avatar
rdenis
The DRL option is a programmable parameter within IDS. Your dealer should be able to do it in about 30 seconds.
Old Dec 23, 2010 | 05:25 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Old Dec 23, 2010 | 06:49 PM
Y2KPSD's Avatar
Y2KPSD
Originally Posted by PowerStrokeHD
Yep, rdenis is correct. You will need to have the DRL parameter enabled.
While they are standard from the factory for Canada bound trucks, they are only available in the US to fleet customers with a valid FIN.
PSHD,
Are you implying that "most" US dealers would not enable DRL for non fleet users due to this requirment?
Old Dec 23, 2010 | 10:06 PM
PowerStrokeHD
Old Dec 24, 2010 | 07:44 AM
6.7Fan's Avatar
6.7Fan
Ahhh. Great Info. Daytime running lights give me a slight savings on my auto insurance. Since it wasn't listed when USAA pulled my VIN, I'm not getting that discount. I'll get this done next time I'm at the dealer. Thank you!
Old Dec 26, 2010 | 04:08 PM
srkr's Avatar
srkr
English please.
IDS?
How should I ask my service tech? Everytime I come up with a weird request, he's clueless.
Shane
Old Dec 26, 2010 | 04:19 PM
rdenis's Avatar
rdenis
IDS is the integrated diagnostic system software used by Ford tech's to analyse the vehicle's on-board computer systems. Typically they run the software off their laptop which is then connected to a VCM (vehicle control module) which is then connected to your vehicle through the OBD-II connector just below and to the left of your steering wheel. You will hear the term IDS and VCM used interchangeably but IDS is software and VCM is hardware. You need both to program or change programming on the truck.
There is a menu option within IDS that allows changing certain programming parameters - daytime running lights is one of them.
The only other thing is the software version - some guys are terrible at updating their software so as long as your guy is relatively current (say version 68 or better) he should be able to do just fine.
Old Dec 26, 2010 | 04:41 PM
srkr's Avatar
srkr
Thank you.
Also, what does this mean?
*Requires valid FIN*
Do all superduties have the option of DRL's?
While he is in there programming, should I ask for anything else?
Again, Thank-you.
Shane
