HELP A/C Fan trouble
Old Dec 23, 2010 | 01:42 PM
4x4EX6.0's Avatar
4x4EX6.0
I lost all controls over the A/C fan it is stuck on High the head unit won't control the speed the steering wheel controls won't control it either. If I turn of the head unit the fan still blows out the defrost vents. Shut off the vehicle and turn it back on didn't help either. Any suggestions or solutions would be great appreciated.
Old Dec 23, 2010 | 05:09 PM
Brians97F250Crew's Avatar
Brians97F250Crew
Is the display lit on the climate control?
Old Dec 24, 2010 | 03:03 PM
4x4EX6.0's Avatar
4x4EX6.0
Yes full control of all other controls except fan only blows on high even when you turn the climate controls to off the fan continues to blow it just switches to the defrost vents which I am assuming that is a default. The only way to get it to shut off is turning the ignition off.....as soon as you turn the ignition back on it immediately comes back on
Old Dec 24, 2010 | 05:21 PM
Brians97F250Crew
Might be your high blower relay is stuck. Or your fan resistor is shorted out. Look under the hood on the passenger side at blower motor.
duvaller
Sep 3, 2015 02:18 PM
CNGBuff
Aug 31, 2015 07:06 AM
lakewood
May 17, 2015 09:28 PM
GR8NW
Jan 24, 2014 03:47 AM
