Block Heater Cord Problem!
Old Dec 22, 2010 | 05:30 PM
YoungFordAddict66's Avatar
YoungFordAddict66
Ok my question is will my block heater work woth only one square prong and the round one? because yesterday i went to plug it in and found one of the square prongs from the plug-in in my extension cord. so i was wondering if it still might work or will i have to get a new one? and where can i get a new one if need be. thanks, blake.
Old Dec 22, 2010 | 05:38 PM
mq1shooter's Avatar
mq1shooter
No, maybe....and then maybe a quick FLASH!... and go to a hardware store and pic up a "cord end" plug, with ground lug..rated at 15 amps should be good.
Old Dec 22, 2010 | 05:43 PM
makomark's Avatar
makomark
Not likely.
Best thing to do is cut of the old plug and replace it with a new one. If you "need it today" the generic one from the hardware store will work. The best approach is to get a "weather-tight" one from an electrical supply house.
Old Dec 22, 2010 | 06:03 PM
mq1shooter's Avatar
mq1shooter
Ford Powerstroke Diesel Block Heater Cord 6.0 6.4 L
Probably a better choice then my earlier post....like Makomark said..."needs to be weather-tight"
...OH Heck..that's for a 6.0...I quit!
Old Dec 22, 2010 | 06:06 PM
Robbgt's Avatar
Robbgt
Just put a HD all weather one on from the local hardware store. $4. It did a good job sealing as is, threw a little silicone in there for good measure
Old Dec 22, 2010 | 07:53 PM
YoungFordAddict66
ok will the 6.0 one work? and just picking up a weather tight one from the hardware store will work? can it handle it?
Old Dec 22, 2010 | 09:06 PM
makomark's Avatar
makomark
should be fine.
You guys have it made....hardware stores with a broad selection.
A big piece of some 6X shrink tubing would be fine for excluding the elements, too.
Old Dec 22, 2010 | 09:18 PM
YoungFordAddict66
yea i just got the same advice from my dad. i guess the same thing happened on his old cc psd so he just cut the old one off and put a new on so i think i might just do that. easier and a lot cheaper and water-proof. thanks guys saves me money and time again.
Old Dec 23, 2010 | 11:46 AM
jtexfisher's Avatar
jtexfisher
Question? Where should the block heater cord actually belong? Mine just hangs under the left front. I can't believe they are s'posed to just hang in the elements like that.
Old Dec 23, 2010 | 11:58 AM
Action4478's Avatar
Action4478
Or ....this ....
Old Dec 23, 2010 | 12:01 PM
YoungFordAddict66
its should be inside the bumper. there should be a piece of hard rubber i think it is going from the bottom of the radiator, IIRC, to the bumper to give u a place to hang the cord. atleast thats what i have.
Old Dec 23, 2010 | 07:17 PM
Ken_C's Avatar
Ken_C
i shove mine in the air duct over the left battery when im not usin it. i need to replace the plug end on mine too. not broke yet but some green corrosion goin on there. you know its drawing some amps when the extension cord melts a line in the snow around it. not warm enough to feel warm to the touch but definitly warmer than the snow
Old Dec 23, 2010 | 07:59 PM
YoungFordAddict66
yea i had to start using a thicker guage extension cord cause the smaller one i was using got kinda warm. u could zip tie it up to the bumper or near it.
JTATMAN
21
Mar 9, 2015 07:04 PM
batfire2000
Mar 3, 2013 11:05 AM
oneway
Feb 14, 2009 02:50 PM
CheaperJeeper
35
Nov 13, 2008 06:01 PM
Reidicus
Jan 11, 2007 11:29 PM
