Fuel pressure is very low. If it's leaking, something is fundamentally wrong. Don't mess with goop, figger-it-out. Not worth a fire.
Good Luck
True that for fittings, but in my case I use Seal All or Permatex for things like the jet plugs on Strombergs and Holleys. I also use it on the Stromberg float pins. No pressure there, but they can seep, which is unsightly.
I have used a glue(SEAL ALL comes in a yellow tube with red letters) on a gas can
it never leaked the package says "GAS & OIL RESISTANT" i know of a couple of other
people that have used it & they are happy with it,now i am not saying to use it on your fittings,but if you are looking to fix a gas container,etc well it worked for me
