Sponsored by: Real Truck
Does the computer learn ?
Old Dec 21, 2010 | 06:50 PM
V10ZILLA's Avatar
V10ZILLA
Hello all,
I was told this and was wondering if it is true. I was going to but some bigger size tires. I have 265/70 r17, (stock).
I was going to buy 285/70 r 17 or 285/75 r 17.
I was told that when you install a bigger tire on these newer SD's that the computer will learn the tire size after a certin milage amount, and then adjust the speedo calibration.
Is this true. Or do I still need to go to the dealer and have them adjust via the computer.....
Thanks
Old Dec 21, 2010 | 07:08 PM
Kajtek1's Avatar
Kajtek1
Do you have factory GPS ? Cars equipped with one do have speedo adjustment as the option. Don't know about your Ford.
Old Dec 21, 2010 | 07:15 PM
V10ZILLA's Avatar
V10ZILLA
I do not have the factory GPS option.
Old Dec 21, 2010 | 09:26 PM
galaxie641's Avatar
galaxie641
No it will not learn but beware the dealer may very well not be able to adjust it either. Your best bet would be to buy a tuner and change it that way as long as have the benefits of a tuner.
Old Dec 21, 2010 | 09:28 PM
MisterCMK's Avatar
MisterCMK
The dealer can adjust the speedo. I had my 07 corrected by Ford before I got my tuner when I went with 285s.
Old Dec 21, 2010 | 09:30 PM
Fordfanatic4life's Avatar
Fordfanatic4life
no it wont, you with have to have the PCM adjusted for the tire size.
i had it done on my 03 at Ford when i went up to 35" tires.. doesnt affect the speedo thou, it just affects shift strategys in the trans.
Old Dec 21, 2010 | 10:02 PM
V10ZILLA's Avatar
V10ZILLA
All good info to know. Thank you all. So I will have to go to the dealer have them adjust it. The adjustment will not correct the speedo but will adjust the tran shifts.
Thanks
Old Dec 21, 2010 | 10:05 PM
MisterCMK's Avatar
MisterCMK
The adjustment will change the speedo. I think mine ran about $65 to have done.
Old Dec 21, 2010 | 10:08 PM
06silvercrew's Avatar
06silvercrew
Sure the ECM learns, its called adaptive learning, however its impossible for it to learn tire sizes.
Old Dec 21, 2010 | 11:30 PM
V10ZILLA's Avatar
V10ZILLA
Ok I will go to the dealer and have it done regardless. Wondering if there is only certain tires sizes that their computer will allow them to adjust for. Meaning 285/75r17 is really not a size offered by most tire companies. 285/70r17 is offered by most of them. So I am thinking that the dealer only has a few choices to adjust to for safety and liability stuff.
Old Dec 22, 2010 | 04:23 AM
cliles55's Avatar
cliles55
B-K Ford in Waco had to change the PCM settings to calibrate the speedo due to taller tire. Didn't cost too much (less than $20).
Old Dec 22, 2010 | 02:13 PM
galaxie641's Avatar
galaxie641
That is exactly what I discovered with our '05 the dealer had certain choices and the tires we had put on were not one of them so it was a waste of the $100, which they of course charged even though they did nothing. That is why I think it is better to put that money towards a programmer.
Old Dec 22, 2010 | 09:12 PM
V10ZILLA's Avatar
V10ZILLA
Thats what I was thinking. I have a friend who works at a lincoln mercury dealer. I will see if he can tell me what sizes they can adjust and go from there.
Old Dec 23, 2010 | 07:27 AM
cliles55's Avatar
cliles55
The service writer at first told me they could only adjust for 17-in. wheels since the truck originally was equipped with 17-in wheels; why, I don't know. So I used this tire website to determine an approximate 17-in wheel tire size. For the stock tire, I used the current tire on the truck; new tire was the equivalent 17-in wheel tire size. Gave them the equivalent tire size but nevertheless, they were able to calibrate it to gnats-a$$ speed when compared to the GPS. The website also gives the revolutions-per-mile info if the dealership needs that info as well.
Hope this helps,
Old Dec 23, 2010 | 07:57 PM
V10ZILLA's Avatar
V10ZILLA
Thanks good info to know
JohnnyQuest
30
Jul 8, 2014 12:44 PM
tackla1326
May 13, 2014 08:40 PM
MattyJessome
2004 - 2008 F150
Apr 4, 2012 09:19 PM
searay5150
2004 - 2008 F150
13
Nov 6, 2011 07:36 AM
Dan4494
1997 - 2003 F150
13
Jan 27, 2007 10:44 PM
