Hello all,
I was told this and was wondering if it is true. I was going to but some bigger size tires. I have 265/70 r17, (stock).
I was going to buy 285/70 r 17 or 285/75 r 17.
I was told that when you install a bigger tire on these newer SD's that the computer will learn the tire size after a certin milage amount, and then adjust the speedo calibration.
Is this true. Or do I still need to go to the dealer and have them adjust via the computer.....
Thanks
Reason: spelling
No it will not learn but beware the dealer may very well not be able to adjust it either. Your best bet would be to buy a tuner and change it that way as long as have the benefits of a tuner.
All good info to know. Thank you all. So I will have to go to the dealer have them adjust it. The adjustment will not correct the speedo but will adjust the tran shifts.
Ok I will go to the dealer and have it done regardless. Wondering if there is only certain tires sizes that their computer will allow them to adjust for. Meaning 285/75r17 is really not a size offered by most tire companies. 285/70r17 is offered by most of them. So I am thinking that the dealer only has a few choices to adjust to for safety and liability stuff.
Reason: grammary
That is exactly what I discovered with our '05 the dealer had certain choices and the tires we had put on were not one of them so it was a waste of the $100, which they of course charged even though they did nothing. That is why I think it is better to put that money towards a programmer.
Thats what I was thinking. I have a friend who works at a lincoln mercury dealer. I will see if he can tell me what sizes they can adjust and go from there.
The service writer at first told me they could only adjust for 17-in. wheels since the truck originally was equipped with 17-in wheels; why, I don't know. So I used this tire website to determine an approximate 17-in wheel tire size. For the stock tire, I used the current tire on the truck; new tire was the equivalent 17-in wheel tire size. Gave them the equivalent tire size but nevertheless, they were able to calibrate it to gnats-a$$ speed when compared to the GPS. The website also gives the revolutions-per-mile info if the dealership needs that info as well.
