Highboy Suspension
Old Dec 21, 2010 | 01:54 PM
bsneed's Avatar
bsneed
Highboy Suspension
I have a 77 highboy and noticed the suspension looks like it has sagged alot. I've heard that a stock highboy can fit up to 37's no problem but mine is running on 33's and would rub with 35's. There is only about 4 inches between the bottom of the front leaf to the bump stop. Is this the way it should be? Are there any suspension kits out there that have a softer ride and dont have alot of lift. I dont want to run more than 37's.
Old Dec 21, 2010 | 02:06 PM
704 dentside man's Avatar
704 dentside man
You should definitely be able to run 35's no problem, but it seems to be hit or miss as to whether 37's will fit (my guess is either spring sag or different suspension/spring ratings). also keep in mind...just because it is a 77, doesn't mean it's a highboy...if it's before serial number Y20,001 it is. As for lift, I'd probably do a rear shackle flip, then either Deaver or skyjacker springs up front.
Old Dec 21, 2010 | 03:38 PM
bsneed's Avatar
bsneed
Thats what i was thinkin 35's should be easy. Its definetley a factory highboy. Divorced t case, narrowed frame, front crossmember its the real deal.
straight-shot
Mar 30, 2014 11:53 PM
jseim44
May 7, 2013 11:18 AM
ol74hb
37
Jan 28, 2009 08:37 PM
YoungMT Hick
Offroad & 4x4
16
Aug 30, 2006 03:12 PM
Graffe
Apr 12, 2002 07:09 PM
