more 4x4 conversion ???? again
Old Dec 20, 2010 | 06:57 PM
bronkntrukholik's Avatar
bronkntrukholik
I know alot of members say just buy a 4x4 and be done with it, I Have a few 4x4s already but I am pondering the idea of making my '77 4x2 f150 supercab shortbed into a 4x4. I like the look of the lifted supercab shortbeds, I know the front cross member is one of the biggest problems. My question is, my plan is to run atleast 35" tires, so that means a lift is needed (maybe 4-6"), would I be able to do a leaf sprung front axle and let the crossmember alone or? If anyone has done this, any help is appreciated. I searched the sigh, but wanna know bout the lifted leaf swap? I have a majority of the parts I need and can have extras fabricated.
Old Dec 20, 2010 | 09:10 PM
4x4 Bart's Avatar
4x4 Bart
In the gallery pictures, there is a 68 or 69 F350 2x4 dually flatbed converted to 4x4 that I believe has an uncut front cross member. They accomplished this by what looks like a huge lift.
I have also seen one done with a large notch cut out and reinforced for the diff center section to have enough clearance at full front suspension compression. I think notching is a better option.
Old Dec 21, 2010 | 10:49 AM
samickguy15's Avatar
samickguy15
Supercab trucks are already leaf sprung in the front I believe, so that takes care of half the problem. I would solve any crossmember issues with a lift. That will help you clear tires too.
Old Dec 21, 2010 | 11:55 AM
JBandit03's Avatar
JBandit03
I dont remember for sure how much lift but 6" rings a bell as far as clearing the crossmember. 4wheel offroad mag did an article converting a truck using a right hand drop axle and showed the way they notched the crossmember. I've been eyeballing this before and have decided that when/if I do this conversion I will probably cut the stock crossmember to make a tube style crossmember in its place.
If you look back through for posts by 75F350, there's a good bit of information about the swap.
Old Dec 21, 2010 | 12:41 PM
ChaseTruck754's Avatar
ChaseTruck754
There's some good pic in here on how 1 guy did it.
1978 Ford F100 cummins conversion - Dodge Cummins Diesel Forum
Now if I were to do a 2wd to 4wd conversion I'd do a radius arm and coil over setup.
Old Dec 21, 2010 | 04:49 PM
bronkntrukholik
That has some pretty good info, it may just be worth it in the long run to cut a 4x4 cross member out of a donor like he did rather than keeping the 4x2 cross member! Thats why research and questions before hand make life alot easier.
march
Mar 12, 2014 08:10 PM
bryanmartin
Jul 18, 2013 04:49 PM
bupton
Dec 2, 2012 05:01 PM
Gage2502
Mar 7, 2011 02:26 PM
