Hey guys. My intake has duct tape all over it from the previos owner (who took horrible care of this truck) come to find out the boot or whatever is cracked. Should I just replace it or go with an aftermarket of some kind. It looks like I'm also missing the piece that goes from the grille to the box itself.
If it still has the OEM air filter system replace it with an after market ie 4437 Nape et al. Check the turbo wheel for damage as the OEM system was notorious for letting dirt through and causing damage.
Yup, what he said. If you don't have the time to build your own then tymar is the way to go. Mine doesn't look pretty, but it works. I'll post a pic with the parts I used if you like
