Most likely 3.55s. Aren't yoou planning a big lift and stuff too?
If so, now is the perfect time to swap to lower gears. Pick a tire size, than match your gears to that.
yes i do but i dont kno **** about the ratios and what they do but a 4:10 gear is lower or higher not sure my buddy was the one that said to run the 4:10s
What size tires do you plan to run? motor and trans?
no you will get 1 ring gear and 1 pinion gear, (reverse rotation for the front) i have not come across a kit that has the 2 sets. but also have only been looking for the front set.
has any one bought a ring and pinion on hear one you buy them do they give you 2 for the fornt and back not sure says sold as a set so i dont no
PLEASE. Try using some grammar and punctuation. It will make reading your posts a lot easier.
As far as i think what you are asking, a set means 1 ring gear 1 pinion gear.
