Sponsored by: Real Truck
unplugging the battery clear codes ?
Old Dec 20, 2010 | 11:43 PM
Fordfanatic4life's Avatar
Fordfanatic4life
often wondered that..
or do you actualy need a code scanner tool to get teh "check engine" light to turn off after a repair ?
reason i ask is cuz i was fiddling around with the seal on my airbox (after the recent repair i had done), and sure enuf the rubber seal doesnt stay in there very well, and when i started it up the seal had popped out again and now the check engine lite is back on..
dont really wanna take it to Ford just to get teh check engine lite turned back off, hopnig i can unplug the battery to get the lite to switch off...
think i'm going to have to order a replacement seal aswell, either that or i'll have to figure out a way to glue it in place, its pretty obvious teh rubber isnt the right shape anymore to simply stay in on its own..
Old Dec 21, 2010 | 12:49 AM
Zedrive's Avatar
Zedrive
The light will reset [go off] after you do a battery disconnect reconnect.
Old Dec 21, 2010 | 06:48 AM
06silvercrew's Avatar
06silvercrew
Disconnect both cables and touch them together for 10 seconds, it will drain all the capacitors in the various ECM's instantly and clear all DTC's.
Old Dec 21, 2010 | 06:45 PM
Fordfanatic4life
ok thx i'll do that and look into doing somethin to get that dam seal to stay in place..
Old Dec 21, 2010 | 06:51 PM
sandmanf250's Avatar
sandmanf250
sealing it properly
if you don't fix the problem the light will come back on.
Old Dec 21, 2010 | 09:32 PM
Fordfanatic4life
yea thats why i gota get the rubber seal to stay in first..
just glad i dont have to take it to Ford just to have the code removed when im done. seems a waste of money really.
Old Dec 22, 2010 | 06:30 PM
Fordfanatic4life
got it sorted today..
thx for teh help guys..
that plug should be in there for life now, hahah
MCGA
18
Apr 21, 2023 03:23 PM
PPrash
Dec 27, 2016 01:12 PM
Vrybusy
6.7L Power Stroke Diesel
32
Apr 29, 2016 08:29 PM
DSMMH
Jan 23, 2013 08:12 AM
heckinohio
Mar 12, 2011 10:21 AM
