While looking for the infamous PCV Elbow, I found a rubber elbow that was "sucked in" coming off the rear top of the engine. The elbow has a 1/2" or so hose coming fro it. At teh base of this rubber elbow there is a small 1/8" or so hose coming out that is attached to a plastic post, the small hose has a hose clamp on it. When I removed the small hose fluid poured out. The larger rubber is in bad shape and may have a hole. Anyway, the suction "sucked in" area is at the bend and it looks like the sucked in area is cutting any flow around the 90 degree bend. I appreciate any thoughts you can give. Also, how do you replace this rubber elbow?
You can buy the replacement elbows at the stealership. Do a search for the part number. I have seen it in a previous post somewhere. I have also been told that you can use a 90* spark plug boot.
Thanks! dealership was closed. AutoZone only had a radiator bypass hose in a 90 degree in the same size. It seems to be working I guess I will leave it on, and get the actual one from the dealer to keep on hand.
Here's the part number that you need F65Z-6762-BB elbow, thats Ford Part Number hopes that help i got the picture of the part but don't know how t post pictures....
You have to upload the pictures elsewhere (like: Image hosting, free photo sharing & video sharing at Photobucket ) and then link to them. You can use the yellow image icon at the top of a new message window and insert the image's link in the box, or you can just put [IMG] before the link and [/IMG] at the end of it.
I have the same question, what was the fluid that came out of the smaller hose above the 90 degree elbow? Was it brake fluid? and if so will there be a problem with air in the line now?
How I post my pictures:
Print out these instructions
1)On the main menu (not the browser menu) of the page where you would post a new topic, click on “User CP” (far left on menu)
2)On the left –hand side, look under “Networking” click on the “Pictures and Albums” link
3)Click “Add Album”
4)Give your album a title, and you must enter a description, and be sure “Public” is checked; hit “Submit”
5)Now open the album you just created and click on “Upload Pictures” link
6)Use the “Browse” button to navigate to where the image(s) is stored on your pc; you may upload 3 images at a time. NOTE: for each image:
a) max. size = 800 x 600 pixels (check the setting on your digital camera)
b) max. file size per image = 97.7 KB
c) you can store a max. of 60 images per album
7) Click on the “Upload Pictures” button
8) Now that you have placed an image(s) in your new album you’ll need to do
a little bit more
9) Go back to the forum page so you can start your new post (or reply) whichever the case
10) To post an image use New Thread (if you are starting anew thread) or Post Reply (if you are replying to someone else’s post) (DO NOT use Quick Reply)
11) Type your message and put the cursor wherever you want to insert the image
12) Go back to your album, click on an image, scroll down, and copy the Picture URL text
13) Go back to where you’re editing your post (make sure cursor is where you want the image to be inserted)
14) Just above the message text-editing area, click on the Insert Image icon (hold your mouse over each icon until the tooltip text tells you which one is the correct icon (looks like a mountain with yellow sky and a sun)
15) Paste in the URL from step 12; Press the OK button
16) Your image was retrieved from your album placed inside your post/reply.
on mine the fluid was coolant, and this is the famous PCV elbow. Local dealer charged me 10.95
When the original part number (F65Z-6762-BB - that you bought) was superceded by the new part number (F65Z-6762-CA), the price went up. Typical of Ford.
i tried something a little different and so far it's working great. bought a foot long piece of 3/8 inch fuel line and cut a piece to match the caved in piece. auto zone charged me 2 bucks for the hose.
I know this is an OLD post but I used it to try to fix my truck . Much rigamarol trying to find the parts others have suggested. Turns out the part at the end of pcv valve hose isn't supposed to come off. It's made to the pipe. And here's the piece https://www.autozone.com/emission-co...eVehicle=false
