Drive 3
Old Dec 20, 2010 | 04:21 PM
Dub Ya's Avatar
Dub Ya
Drive 3
Okay, might be a silly thing but I'm not a gearhead and don't really know. I have a 2010 Lariat with the 5.4 in it and I have the center console shifter in between the seats. On this console, there are gear selections ranging from Drive to Drive 1. I ordinarily use only Drive but on occasion, I drop it into Drive 3 for take off. Is that a bad idea? Here is what happens. I put into Drive 3 at a light or stop sign and as I accelerate, it seems as though the clutch is slipping or something like that is happening. Basically, as I hit the gas, it seems as though the engine speed is increasing but the truck isn't moving very quickly which makes me think something is wrong or slipping. It's like its not catching on or grabbing like it should. Not sure if I should even be using Drive 3 in this case but it still seems odd to me. Any ideas or advice? Thnx
Old Dec 20, 2010 | 05:12 PM
shotgunz's Avatar
shotgunz
Read your manual.
3 locks you into 3rd gear. You're starting at a high GR.
2 locks you into 2nd gear.
1 locks you into 1st gear.
Sounds like the transmission is functioning exactly like it should.
Old Dec 20, 2010 | 05:14 PM
n578md's Avatar
n578md
I don't know about the 6R80E but on the 4R75E and 4R70W, when you select "2", ( PRND21) the transmission is ONLY using 2nd gear. It does not use 1,3 and 4. So when I am stopped and I select "2", it does feel like the transmission is slipping and the takeoff is very slow. According to the service department, this is the way Ford transmissions are made to operate.
Old Dec 20, 2010 | 05:31 PM
WV-150's Avatar
WV-150
The only time you should ever need to start out in 2nd or 3rd gear is if you are starting out on ice or slick snow.It drastically cuts your power to prevent spinning.I don't think it is wise to do this unless you have to.If you did that with a standard transmission a lot what will happen?Right, a burned out clutch.
Old Dec 20, 2010 | 10:29 PM
Dub Ya's Avatar
Dub Ya
Thanks guys....I kinda feel dumb. It makes sense now that I read the replies here. I won't be starting out in Drive 3 anymore unless on ice, etc. Thanks!
Old Dec 21, 2010 | 10:44 AM
04XLTRUNNER's Avatar
04XLTRUNNER
yeah, its not like the older chevy truck where you had 1,2,D,and overdrive. Drive nowadays means drive/overdrive, 3 is 3rd and so on. that is why we have tow/haul buttons to disable overdrive.
Old Dec 21, 2010 | 11:39 AM
shotgunz's Avatar
shotgunz
In the 09-10 (maybe the 11s), T/H does not disable 6th (overdrive).
Old Dec 22, 2010 | 06:16 AM
stormsearch's Avatar
stormsearch
Repeat post
Old Dec 22, 2010 | 07:34 AM
WV-150's Avatar
WV-150
Just a comment. I think Ford has the only transmissions that if you put it in 2nd or 3rd it will start out in that gear.GM,Toyota,Dodge I think start out in 1st but will only go up to the gear you put it in.Correct me if I am wrong.
Old Dec 22, 2010 | 07:40 AM
deltaboost's Avatar
deltaboost
my 06 silverado had 1st and 2nd gear start, and putting it in third simply kept the trans from shifting into 4th, up to a certain rpm at least.
Old Dec 22, 2010 | 09:46 AM
04XLTRUNNER
Your right, my mistake. I dont know why I said that. I just changes the shift points, and firmness and holds the gear longer. I have used it a few times on heavy loads, and up in the arkansas mountains.
Old Dec 22, 2010 | 07:36 PM
superrangerman2002's Avatar
superrangerman2002
3-2-1 is also meant for times when you don't want the tranny to shift and want to use the HP of the motor....i.e. pulling stumps, mud, deep snow etc.
I've learned that 2nd or 3rd is friggin awesome with the locker kicked in. Just low enough to keep from bumping up on the 25mph trigger, but a whole lotta power to go through the wicked deep stuff.
A few weekends ago I was marching right through bumper deep plus heavy snow in 4x4, rear locked and in 2nd or 3rd.
Old Dec 23, 2010 | 10:02 AM
jmmec's Avatar
jmmec
Do you know if the locker automatically disengages if you try to make a turn -- or do you always remember to unlock before you make a turn?
Old Dec 23, 2010 | 11:38 AM
shotgunz's Avatar
shotgunz
Download a manual at http://www.motorcraftservice.com and search the pdf for:
Electronic locking differential (ELD) axle (if equipped)
Old Dec 23, 2010 | 01:44 PM
jmmec's Avatar
jmmec
I have RTFM at least twice now, but it doesn't explicitly answer the question, or I missed it if it does.
The 2011 Super Duty elocker will automatically disengage on tight radius turns, but this is a different elocker than that used in the F150 (GKN) -- the Super Duty locker is "similar" to the F150 GKN, but "similar" does not mean "equivalent".
The GKN website is practically worthless -- they don't provide much information. I suspect the F150 GKN elocker would automatically disengage on a tight radius turn, but I have nothing concrete to back to that up, and I don't want to experiment on something that could potentially cause damage.
For the Super Duty:
One of the best options in the 2011 Super Duty is the addition the electronic locking rear differential for the first time that's similar to the GKN-supplied e-locker ...
The e-locker has been designed by Ford and is manufactured at the Sterling Axle plant for single-rear-wheel F-Series Super Duty trucks only.
... The truck will also disengage the locker if it's making a tight radius turn by sensing the steering wheel position, so the rear wheels and tires aren't damaged from scrubbing on pavement.
