Drive 3
Old Dec 23, 2010 | 02:05 PM
shotgunz's Avatar
shotgunz
Based on this:
When the axle is unlocked it will function like a standard rear axle. When the axle is locked it will not allow the rear wheels to rotate at different speeds when turning. The ELD axle is not recommended for use on good traction surfaces such as dry pavement. Doing so may result in abnormal driving behavior while cornering and excessive tire wear.
I would say it doesn't.
Make sense?
Old Dec 23, 2010 | 03:45 PM
jmmec's Avatar
jmmec
It does not address the question raised.
Thanks...
Old Dec 23, 2010 | 04:04 PM
shotgunz's Avatar
shotgunz
The manual doesn't say it does, so I would assume it doesn't.
Especially since the manual clearly states it should not be used on dry pavement as doing so will result in excessive tire wear.
stonerboys
1997 - 2003 F150
Sep 9, 2014 10:13 PM
rfaulk93
Oct 16, 2013 08:35 AM
RSCHAP1
21
Apr 27, 2010 12:54 PM
msgtg
Jul 31, 2009 11:18 PM
