1966 - 1977 Early Broncos
Bronco heater
Old Dec 20, 2010 | 03:30 PM
0351mike's Avatar
0351mike
Bronco heater
I had a question on the OEM bronco heater. I have a 70 wagon that I had put back on the road. The heater core is new and I have had the box and vent lines completely out of the truck. I am getting very little air movement out of this fan. Has anyone tried to upgrade this system- will a motor or just the fan work out of a 73-79 F150 or 79 bronco- they look pretty similar and I do not remember having an issue with them. Is there an aftermarket system that works well?
Old Dec 20, 2010 | 04:46 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
There is a Chevy blower conversion that is a popular upgrade. I will try to find a tech article for it on another site. Here it is, you might have to do some reading: http://classicbroncos.com/forums/sho...wer+conversion
Old Dec 21, 2010 | 09:12 AM
0351mike's Avatar
0351mike
Thanks- I will give it a try- seems easy enough.
Old Dec 30, 2010 | 05:48 PM
dodmort's Avatar
dodmort
I put in one of the Mojave's
really small and makes things very HOT
even with windows down so you can see where ur going
Frees up all that space for a very large storage area also.
the do make a plenum for them too.
Old Dec 31, 2010 | 11:50 AM
0351mike's Avatar
0351mike
heater
I have seen them in JBG- does it or can it replace the OEM box and core or is it just supplemental to the stock set up?
Old Jan 1, 2011 | 04:10 PM
chrlsful's Avatar
chrlsful
Mojave Heater & Plenum
(click above) Yes, the typical EB vendors sell them, yes they can B either (many use them in place of the oem just hook up the water hose, use orig. h. control valve) or as aux. (back seat) and
NO
I do not like them.To each his/her own, however (that's why there's chocolate n vanilla).
The oem is fine. May need gaskets or ck the fan/ducts/2" hoses. But as some 1 said - "mine blasts me out" the 1/2 cab (did when it wuz wagon too) plowin all winter long in the Berkshires @ 2 and 4 am.
Old Mar 31, 2011 | 11:00 PM
70 Bronco TX's Avatar
70 Bronco TX
Well a little late to the discussion, but I did the Chevy motor and wheel conversion and it was real easy. Puts out a lot more heat and air. Did a heater core replacement just before, too, not a fun process but had to be done (leaking). I'd recommend the change.
TexanAmmo
55
Jul 22, 2018 06:42 PM
tap1946
Nov 28, 2017 12:19 PM
Kenneth J Kirkland
Dec 23, 2016 02:47 PM
Thunderhorn
Nov 9, 2015 09:17 PM
secakc
Jan 29, 2011 04:53 PM
