Stuck Tailgate
Old Dec 20, 2010 | 02:27 PM
makthenif's Avatar
makthenif
Question Stuck Tailgate
2002 Expedition
I closed the tailgate one day and now it won't open. The glass will open, but the bottom lock won't. We can hear movement around the lock but it is just stuck.
How can i fix this? I would rather be able to do a DIY then take it to a mechanic and pay to much for a simple solution if there is one.
Thanks
Old Dec 20, 2010 | 06:49 PM
I fish's Avatar
I fish
Sounds like a problem with the linkage. Remove the trim and take a look inside. probably nothing major
Old Dec 21, 2010 | 12:03 PM
makthenif's Avatar
makthenif
ok, i will try that. anything special about the trim removal? thanks
Old Dec 21, 2010 | 12:28 PM
secondechomatt's Avatar
secondechomatt
just hit around the lock area with your palm.
then step back and say... AYYYYYYY like the fonz.
works everytime.
Old Dec 21, 2010 | 06:45 PM
I fish's Avatar
I fish
Should be pretty straightforward, but i haven't done it in a while. i seem to remember a couple screws at the top, above the window, and a couble at the bottom. if you run into trouble give a shout and i'll take a look to refresh my memory
Old Dec 31, 2010 | 04:37 PM
dpetershagen's Avatar
dpetershagen
stuck liftgate
Were you able to fix it? My Navigator is also stuck closed and I'm not sure how to get the panel off with the gate in the closed position.
Old Jan 4, 2011 | 11:17 AM
makthenif's Avatar
makthenif
i haven't tried yet.
Old Jan 6, 2011 | 10:41 AM
dirtmonkey11's Avatar
dirtmonkey11
Sounds like the linkage the is not unlocking the latch assembly for the door. Most likely it either popped off somehow or broke.
Old Jan 6, 2011 | 01:04 PM
alwaysfords41's Avatar
alwaysfords41
Captain Obvious, there's a call for you on line one....
Bluegrass F250
Sep 3, 2020 10:45 PM
jobdestin
Nov 30, 2018 09:12 PM
LawBoy01
Jun 26, 2014 06:22 PM
jslaymon
Apr 13, 2011 07:55 PM
NitrousAl
1983 - 2012 Ranger & B-Series
Jan 16, 2005 07:14 AM
