'90 Tailgate won't open.
Old Jan 15, 2005 | 08:49 AM
NitrousAl's Avatar
NitrousAl
Question '90 Tailgate won't open.
Does anyone have an idea how to open a tailgate with a malfunctioning handle? It lifts up, but the tailgate won't open. Can it be fixed or do I need anoth tailgate? I was going to take a crowbar to it, but I don't want to wreck my truck.
Old Jan 15, 2005 | 01:15 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Isn't there an access panel on the inside the bed surface of the tailgate that can be removed?
Old Jan 15, 2005 | 04:57 PM
NitrousAl's Avatar
NitrousAl
Thanks for the info. I completely forgot about that panel. It's covered by the bedliner. It's too dark now to take a look at it, but I will in the morning. Thanks again!
Old Jan 15, 2005 | 10:26 PM
el conquistador's Avatar
el conquistador
there is no need to take the screws out on the inside of the tailgate. you can access the hardware by simply looking up under handle itself (dont need to take the panel off), you will see the springs and the rest of the assembly. just needs some graphite or in my case i needed penetrating oil to free it up. worked like a charm.
Old Jan 16, 2005 | 01:22 AM
hood's Avatar
hood
Lube it up with some WD40 or similar lubricant. If you get it to open, be sure to lube or grease both sides where the gate latches at. The finger pins that go into the slots tend to get stuck when not used alot.
-hooD
Old Jan 16, 2005 | 03:15 AM
NitrousAl's Avatar
NitrousAl
Question
So all the moving parts just need to be shot with some WD-40? It's not something more serious than that? I thought the handle was broken or something.
Old Jan 16, 2005 | 06:46 AM
Ranger Lance's Avatar
Ranger Lance
Screwdriver will do it. I had this happen to me so I'm going from memory:
Hold the handle up and while doing so get the screwdriver between the right side of the tailgate and the side body panel and work the "hook" coming from the tailgate off the stud. If need be, do the same thing on the left side also.
I got an aftermaket tailgate handle off ebay cheaper than an OEM and it was all metal. Common problem; get an all metal off ebay. (Go to ebay motors; search; type in ford ranger metal tailgate handle; click active items). They're less than $20.
Old Jan 16, 2005 | 07:09 AM
NitrousAl's Avatar
NitrousAl
Thanks for the info. I'll look on eBay for the handle. I want to fix this problem so it never happens again. I moved my mother-in-law recently lifting everything over the tail gate (washer, fridge, etc). I invented curse word during that move. Try deadlifting a large AC a couple of times. She had two.
Old Jan 16, 2005 | 07:14 AM
Ranger Lance
You're welcome Al. Hey this is where I got the fix for mine (this forum). The all metal handle is great!
Bluegrass F250
Sep 3, 2020 10:45 PM
Warpburn
Aug 23, 2018 08:29 AM
Chris Karsseboom
Jun 13, 2017 11:07 PM
jslaymon
Apr 13, 2011 07:55 PM
bro chuck
Jun 1, 2007 07:04 PM
