Alright guys, I've got a 6.7 and had it flashed with the 400/800 upgrade, now it gets 5-6 MPG lower than it did before and is using the whole tank of urea in 2500 miles and it's shifting harder than it did before the flash.
Took it to Ford and they said they couldn't flash it back to the OEM prog, which I'm pretty sure is a lie. What is the code for the OEM flash?
There is definitely a problem here. Roughly 100000 trucks received the new 400/800 upgrade. There have been less than a handful of complaints. Find a better dealer
Why can't they just re-flash to OEM? I can change my 6.0s back and forth however I want.
I'm not sure what you are flashing a 6.0 with, but even on them the IDS that the techs use will only flash forward not backward. You are limited to flashing the truck with whatever strategy is part of the version your IDS is running. There are ways of doing it, but I guarantee you the dealer can't do it.
could be...If you are referring to using a tuner for switching between the current factory programming on your 6.0 and the tuners programming, there is a big difference with factory returns to old programming. You are storing the factory programming on your tuner and installing the tuner programs. The tuner makes no changes to the "factory flash". The factory re-flash programming overwrites the old programming but does not save the old programming. Ford does not allow the dealer techs to control what they install. The IDS system has total control and will not allow a return to abandoned programming. As I said earlier, over 100000 trucks have been re-flashed with a nearly immeasurable problem rate. You do not want the old flash. You want the new flash properly installed. This is all assuming the re-flash is the problem. Time for a good dealership/
High Binder,
You are not alone with the loss of MPG. Mine has dropped the same amount and the dealer has not figured it out yet. I do not have a high DEF usage as you are reporting.
I have had mine to the dealer 4 times for it and the dealer was told by the feild service engineer that they have found that it takes about 2-3K miles to realize the MPG increase after the flash.... you should have seen their face when I said mine has over 6K since the flash.... This is the same feild service engineer that said my bounce at 40-45 is normal... no solutions as of yet, that is why this fuel mpg issue is the second part of my lemon law complaint.
perhaps part of your mileage loss is the transition to blended fuel for the winter?
Not in my case, had the flash done as soon as it came out this summer, noticed the decrease on the way home from the dealership that day. Truck runs fine just sucks fuel. I reset my fuel milage when I left my driveway on the way to the dealer that day and averaged 20.3, on the way in, reset it again at the dealership and averaged 16 taking the same roads. Milage has hovered around 16 since. When towing my 5'er, the milage dropped from 12.5 to 9-ish.
My 2011 F250 3.55 4x4 has never got anyway near 20mpg around town. It averages 16.5 unloaded since it's reflash in August. It did about 16.2 before the flash. It's a far cry from my 08 6.4 which gave me 12 mpg unloaded
Awesome, thanks for the info! Rep coming your way.
High Binder,
Well, I'm on my way to the lemon law with this, as many times as it's been at the dealer. Thanks man rep given.
OK, stupid question time:
What does IDS stand for?
Is the "factory-flash" the what we in 6.0 land refer to as the "strategy"?
