Ignition Module recommendations
Old Dec 19, 2010 | 06:19 PM
krazykat811's Avatar
krazykat811
it there a way to test the IM om the truck? to take it off for testing looks like i have to open tape around the wire harress too pull it, right? I put test light at coil it lights that is if i got it right, I have the square coil, it dosen't have the 2 liitle post it has a wire connecter
Old Dec 19, 2010 | 07:14 PM
Wyowanderer's Avatar
Wyowanderer
Originally Posted by LARIAT 85
Most people that work at AutoZone have no idea what a "feedback" carburetor even is and will look at you funny when you tell them you have a computer and a carburetor on the same vehicle. I have actually went in before to get windshield wipers for my Jeep Wrangler and the salesperson behind the counter asked me if my vehicle was 2wd or 4wd.
that's not been my experience. The store I go to has friendly, knowledgeable staff who are happy to help. If they don't know, they'll try to find out. I'm suprised you haven't heard about the 4WD wiper thing.
The first mistake you are making is buying your parts from AutoZone. Do a search in here and it is riddled with people having failures with their el cheapo parts, and the same goes for Advance Auto and any other "McParts" store out there. Cheap store replacement ignition modules and electronics components are notoriously UNRELIABLE. They will sell you on a "Lifetime Warranty" and, to their credit, will usually honor it. But anyone who has has to replace an in-tank fuel pump more than once is going to tell you it is not worth it. In fact, there are numerous garages around here that clearly have signs that state that they will NOT use customer-supplied parts. I went in to ask them why, and was told the failure rate was too high because customers would bring in the cheap aftermarket parts (ie: AutoZone, Advance Auto, etc.) and then come back when the parts they supplied failed prematurely and try to hold the garage responsible. I asked what parts they used, and I was told they would honor OEM dealer parts or parts from NAPA or CarQuest.
Buying parts from AZ isn't a mistake if you buy brand names and stay away from store brands. I've purchased Bilstein shocks for both my vehicles, and LOTS of Motorcraft parts as well; almost everything has a warranty of some kind-try that at FoMoCo. I've never had anyone at AZ try to SELL me a warranty, either; but if they did, I'd tell them to pack sand. In addition, oil and sealants are the same as any other store, and often less expensive. They can also check your ignition parts, alternators, and starters for free. Try that at FoMoCo. I also find it handy to have a parts store open until 9 PM.
That said, I buy nearly everything at my Ford dealer, if I can.
I replaced my original TFI module on my 1985 F150 in 1999 and it was still functioning fine after I replaced it almost 10 years later with the DSII. I am not sure what "supplied clear paste" or "thermal paste" Wulff is talking about, but I used what FORD (AND Haynes, AND Chilton's) specified: dielectric grease.
I began using thermal paste at the urging of the parts counter employee at Greiner Ford in Casper, who told me that there was a TSB on it. I've looked in alldata, and can't find it. I'll keep looking and post it up when I find it. The point is that thermal paste is always better than dielectric grease for transferring heat away from the module. If you'll open the box on a TFI module from AZ, it comes with a white paste, not dielectric grease. But if you like grease, please use it.
Old Dec 19, 2010 | 07:50 PM
LARIAT 85's Avatar
LARIAT 85
Yeah, that's pretty funny, especially when you know that up until 2006, Jeep Wranglers were not even offered with 2wd.
Correct me if I am wrong, but I just checked the AutoZone website and they do NOT have "LOTS" of Motorcraft parts, Chief. In fact, the ONLY Motorcraft parts I could find for my vehicle (1985 Ford F150) were spark plugs and an oil filter. If they did sell more Motorcraft parts, I would buy from them. I agree with you on shocks, oil, fluids, and cleaning products, but I have learned my lesson on their ignition parts, alternators, and starters.
I bought an alternator from my local Ford dealer a month ago and it came with a 3 year warranty, and the Motorcraft battery I bought for my Taurus also has a 3 year warranty.
I never said AutoZone would "sell" you a warranty; I said AutoZone would "sell you on" a warranty. Meaning a good bit of their parts come with a lifetime warranty that they will honor, and that is what fools most people into thinking they are getting a "quality" part. When you have to replace your in tank fuel pump or power steering pump more than once in the same year, you will find that the warranty isn't worth more than paying a little extra for a quality part the first time.
You are correct that FoMoCo does not have a service that checks the parts you mentioned, so yes, AutoZone does have them beat in this area. That is why I suggested NAPA or CarQuest. They do have that service, have much better quality parts than what AutoZone, etc. carry, and are a good alternative to OEM Ford parts. You can also find a good bit of Motorcraft parts at RockAuto.com.
I believe you when you say this, but I can promise you that the ignition module you got from AZ is not the same ignition module you get from Ford, and that is my point. When I opened up the box on my Ford Motorcraft TFI ignition module back in 1999, it didn't come with any paste at all. It did, however have instructions that said to apply a film of dielectric grease to the back of the module prior to installation.
Old Dec 19, 2010 | 08:37 PM
Sw1tchfoot's Avatar
Sw1tchfoot
He is refering to a thermal paste that is used on computer processors. The paste is applied between the CPU and the heatsink to transfer heat. Even with smooth surfaces on the CPU and heatsink the processor will overheat very quickly without thermal paste to transfer the heat between the two surfaces. It is advertised that it isn't conductive, and it won't dry out from heat.
I don't know if transfering heat from the spark plugs, to the components in the spark plug boot (and the boot itself..) is a good idea. I would bet that dielectric grease itself does the same thing though.
Old Dec 19, 2010 | 10:29 PM
Wyowanderer
I'd like to apologize to the board for my (now edited out) post. I especially apologize the OP.
Larryg99
Dec 31, 2016 04:06 PM
wyoclint
Dec 15, 2016 05:02 PM
jgrohs54
Jan 21, 2016 10:43 AM
jmthunderbirdturbo
1978 - 1996 Big Bronco
31
Aug 24, 2015 01:12 PM
bwoldschool65
28
Sep 10, 2008 09:03 PM
