transfer case motor install ?
Old Dec 18, 2010 | 04:28 PM
hdman6's Avatar
hdman6
Question transfer case motor install ?
I have a 2002 f-350. I am picking up a new Xfer case motor tommorrow to install. Is there anything tricky about installing the new motor? It is from Advance AP. Also how can the xfer case be manually shifted back to 2wd ? It is stuck in 4wd high right now. I have checked all fuses reset all the relays etc. I also cleaned the connectors as well but still dead in the water. It just died last week while the truck was running after using 4wd low. I wouldnt shift back to 2wd from 4wd high and has been there ever since. So I just wanted to know how to shift it manually if I have to back to 2wd and if there is anything to know about the motor install. thanks Jeff
Bob Gervais
Jan 17, 2013 05:14 PM
chris9n
1983 - 2012 Ranger & B-Series
Dec 5, 2007 12:14 PM
dacrazyman
May 6, 2005 10:51 AM
t-burd
Dec 5, 2003 02:32 PM
willywonka316
Jan 2, 2003 06:36 PM
