stuck in 4x4 high
Old Dec 17, 2010 | 04:18 PM
hdman6's Avatar
hdman6
Question stuck in 4x4 high
I have a 2002 f350. I used my 4wd low last week. after I was done I got out unlocked the hubs (warn manual, no vacuum). I then switched to 4x4 high and drove forward. The 4x4 light has been on since. Lucky I have free wheeling front but I did test the hubs again by locking them and it went right into 4wd high, so its enguaged and turning. So today I cleaned the connecter to the motor on the xfer housing, checked all the fuses , looked at the switchbox contacts next to the brake fluid res. They looked good as well. ( I think that is the one). I also had my batteries out to replace the headlamps at the same time. So I checked everyrthing while disconnected. But after all that the 4x4 is still on. So I plan on going over to a friends shop and working on it in the heated garage, what else and how can I check it out to see whats the problem? I wonder if it is the motor (450 bucks I hear) on the xfer. Is there a way I can check the connections? I do have a multimeter but only used it a few times. Any help would be great. Thanks Jeff
Old Dec 17, 2010 | 07:31 PM
woodnthings's Avatar
woodnthings
You can pull the motor and shift it manually. While the motor is out you can operate the switch to see if the motor is working or not. I don't think the motor costs that much on Rockauto.com it is about $125.
Old Dec 18, 2010 | 08:01 AM
hdman6's Avatar
hdman6
I was thinking of picking up a motor to have on hand or replace anyways since the truck is 9 years old and maybe the motor will go soon anyay. But how can i check the connection to to motor with the meter? If and if I remove the motor How does it shift manually to 2wd so i can do it manually to get it out of 4wd high? thanks Jeff
svike
Oct 23, 2015 05:59 AM
indyF-350psd
Dec 28, 2012 12:08 AM
hdman6
16
Mar 17, 2012 03:57 PM
PPrash
Aug 17, 2010 03:49 PM
