GPCM
Old Dec 18, 2010 | 12:14 PM
clintbonnie's Avatar
clintbonnie
Originally Posted by armstrongfordtrucks
I plugged it in and it started . I will check tonight by leaving it outside again . I always had dim headlights on my 97 for about 45seconds after it started so I knew they were working.
Thanks for your help.
You can continually monitor your voltage from your cab within a .10 of a volt by using this:
Amazon.com: Vector VEC008 Digital LCD Voltmeter, 12 Volt: Automotive
It is great for watching glow plug activity. I leave mine plugged in all the time..
Old Dec 19, 2010 | 08:35 AM
armstrongfordtrucks's Avatar
armstrongfordtrucks
So, left it out last night, still will not run. It does start but just quits. I used a meter to watch voltage and it went from 12.4 to 11.5 when I turned the key on. I assume that drop is just normal for everything except GP's. Plugged it in to get it back in the garage to continue tests.
Old Dec 19, 2010 | 09:38 AM
armstrongfordtrucks
If I were to call RIFFRAFF, if in stock and I was to purchase this would it tell the problem ?
Ford
94-97 'OBS' 7.3L
Brake Products Exhaust BrakesPower SlotPower StopBumpers/Exterior/Related
Drivetrain/ Related Detroit TrueTracDeraleMag-HytecJohn Wood AutomotiveElectrical / Lighting Brite Box™LightforceEngine Components ARP Head StudsCCV KitDampersFumoto ValveHPXIntercooler BootsMelling LPOPExhaust Products Exhaust AccessoriesExhaust Systems CompleteFuel System & Related FiltrationFuel AdditivesFuel Systems/MiscInjectorsGauges AutometerDigital MonitorsIssproPillars/Misc/RelatedIntake Intake Kits / FiltersCCV KitIntake ManifoldsIntercoolersMisc Items
OEM Parts
Onboard Air / Horns KitsKliennExtreme OutbackO-rings EnginePackage Deals
RDP Products / Kits FRxHPXIntercooler BootsSteps/Running Board AMPARBCARRSuspension
Towing AirbagsAnderson HitchesDerale CoolingTuners/Power Adders DP TunerSnow PerformanceTurbo/Related
99-03 Super Duty 7.3L
Brake Products Exhaust BrakesSSBCPower SlotHawk Performance PadsSkyjacker SS Brake LinesBumpers/Exterior/Related BumpersBushwacker FlaresDrivetrain/ Related Derale CoolingJohn Wood AutomotiveMag-HytecMidwest Trans ShiftersSouth Bend ClutchesARB Diff CoverFord Factory PartsWarn HubsDetroit TrueTracElectrical / Lighting Brite Box™LightforceReconOEMConversion HarnessesEngine Components AIH Delete PlugARP Head StudsCCV KitDampersFumoto ValveHPXIntercooler BootsMelling LPOPExhaust Products Exhaust AccessoriesExhaust Systems CompleteFuel System & Related FiltrationFuel AdditivesFuel Systems/MiscInjectorsHPOP/ RelatedGauges AutometerDigital MonitorsIssproPillars/Misc/RelatedPackagesIntake Intake Kits / FiltersCCV KitIntake ManifoldsIntercooler BootsAIH Delete PlugsIntercoolersMisc Items
OEM Parts Fuel System & RelatedMisc/ UncategorizedSensorsO-rings Combo KitsHPOP & Engine KitsFuel Bowl PartsFuel SupplyTurbo and SensorsInjector OringsFumoto ValvesOnboard Air / Horns KitsKliennExtreme OutbackAccessories/ MiscPackage Deals
RDP Products / Kits FRxHPXIntercooler BootsAIH Delete PlugCeramic Coated Manifolds6637 KitCCV KitsPlenum Reinforcing InsertsRDP Custom F650 Dash KitOCRRiffraff SwagSteps/Running Board AMPCARRSmittybiltSuspension Icon Vehicle DynamicsEnergy SuspensionOne Up OffroadTowing AirbagsAnderson HitchesDerale CoolingRoadmaster Active Suspension KitTurbo/ Related Compressor/ Turbine HousingsCompressor WheelsTurbosTurbo PedestalTurbo OutletTurbo Rebuild KitsWastegate ActuatorsTuners/Power Adders DP TunerSnow Performance00-03 Excursion 7.3L
Brake Products SSBCPower SlotHawk Performance PadsBumpers/Exterior/Related BumpersElectrical / Lighting Brite Box™LightforceReconOEMConversion HarnessesEngine Components AIH Delete PlugARP Head StudsCCV KitDampersFumoto ValveHPXIntercooler BootsExhaust Products Exhaust AccessoriesExhaust Systems CompleteFuel System & Related FiltrationFuel AdditivesFuel Systems/MiscInjectorsGauges AutometerDigital MonitorsIssproMisc/RelatedIntake Intake Kits / FiltersCCV KitIntake ManifoldsOEM Parts
RDP Products / Kits FRxHPXIntercooler BootsAIH Delete PlugRDP Custom F650 Dash KitSteps/Running Board AMPARBCARRSuspension
Towing AirbagsAnderson HitchesDerale CoolingTuners/Power Adders DP TunerSnow PerformanceTurbo/ Related Compressor/ Turbine HousingsCompressor WheelsTurboTurbo PedestalTurbo OutletTurbo Rebuild KitsWastegate ActuatorsMisc Items
O-rings Combo KitsHPOP & Engine KitsFuel Bowl PartsFuel SupplyTurbo and SensorsInjector OringsFumoto ValvesDrivetrain/ Related John Wood AutomotiveMag-HytecARB Diff CoverFord Factory PartsWarn Hubs03-07 Super Duty 6.0L
Brake Products
Intake AEMAFES&BVolantElectrical / Lighting Brite Box™LightforceReconEngine Components ARP Head StudsDampersFumoto ValveHead GasketsEGR DeleteExhaust Products Exhaust AccessoriesExhaust Systems CompleteFuel System & Related FiltrationFuel AdditivesFuel Systems/MiscInjectorsGauges AutometerDigital MonitorsIssproPillars/Misc/RelatedOEM Parts
Onboard Air / Horns KitsKliennExtreme OutbackPackage Deals
RDP Products / Kits Intercooler BootsSteps/Running Board AMPCARRTowing AirbagsAnderson HitchesDerale CoolingTuners/Power Adders
Turbo/Related
Misc Items
O-rings
Suspension Energy SuspensionDrivetrain/ Related Mag-HytecARB Diff CoverWarn HubsOEM CoversDetroit TrueTrac03-05 Excursion 6.0L
Brake Products
Intake
Engine Components
Exhaust Products
Gauges AutometerDigital MonitorIssproPillars/Misc/RelatedOEM Parts
Onboard Air / Horns
Package Deals
RDP Products / Kits
Steps/Running Board AMP Power StepTowing
Tuners/Power Adders
Turbo/Related
Misc Items
O-rings
Suspension
Drivetrain/ Related
2008-2010 6.4L
Brake Products Exhaust BrakesSSBCBumpers/Exterior/Related
Electrical / Lighting Brite Box™LightforceReconExhaust Products Exhaust AccessoriesExhaust Systems CompleteFuel System & Related FiltrationFuel AdditivesFuel Systems/MiscInjectorsGauges AutometerDigital MonitorsIssproMisc/RelatedIntake Intake Kits / FiltersIntake ManifoldsOEM Parts
RDP Products / Kits Intercooler BootsSteps/Running Board AMPARBCARRSuspension
Towing AirbagsAnderson HitchesDerale CoolingTuners/Power Adders Spartan Diesel TechnologyTurbo/Related
Misc Items
O-rings
Engine Components ARP Head StudsDrivetrain/ Related
2011+ 6.7L
Brake Products
Drivetrain/ Related
Engine Components
Exhaust Products
Gauges
Intake
Misc Items
OEM Parts
O-rings
Onboard Air / Horns
Package Deals
RDP Products / Kits
Steps/Running Board
Suspension
Towing
Turbo/ Related
Tuners/Power Adders
Hot New Products
On Sale
Resources
Installation
Links
MBRP
Contact
Events
Riffraff Apparel/ Swag
Secure Socket Layer
Home > Ford > 99-03 Super Duty 7.3L > Misc Items
**48 STATE FREE SHIPPING**
Total Ford Enhanced Bundle
Quantity in Basket: None
Price: $359.97
Domestic Bundle +$281
Quantity:
NOW IN STOCK AND SHIPPING 9 version w/ the ProLine hardware
As of January 1st 2011 the AESP05 Domestic Bundle will increase by $100 as required per manufacturer.
Scan Tool
The package that we offer is the Enhanced Bundle that is for all Ford vehicles. It will allow you to run the common tests on your Powerstroke that can only be done with a fully enabled scanner such as AE.
AutoEnginuity's Scan Tool is a hardware and software combination for Windows ME / 2000 / XP (Pro, Home, and Media Center) / Vista / Windows 7 operating system.
AutoEnginuity's Scan Tool was designed to be as easy to learn—as it is powerful. Scan Tool comes with an automated installation process, a complete and comprehensive User Guide, and an easy-to-use interface. You won't have to spend valuable time learning another piece of software, you can focus on what's important—servicing the vehicle.
What AutoEnginuity's Scan Tool can do:
•Save, print, read and clear Stored and Pending P, U, B, and C Trouble Codes. Supporting P0 - P9 generic and manufacturer specific codes (including the new lettered codes (e.g., P06A0)
•The largest manufacturer specific trouble code library of all PC/PDA-based scan tools (30,000+)
•Read and clear Freeze Frame data
•View live vehicle sensors in a meter, graph, or grid format
•View oxygen sensor live data and test results
•View all 11 Inspection/Maintenance systems and Mode 6 data
•Unlimited logging of live vehicle sensors in TXT, XML, or CSV (1ms logging accuracy)
•Playback your data logs for offline analysis
•Run and query specific component and system tests. Support for generic and enhanced bi-directional tests
•View generic and manufacturer enhanced data on the same tool
•English or Metric (SI) units of measure supported
•Configure your sensors' ranges, scaling value, audible alert triggers, units, and sampling rate
•Savable configurations. Set up the interface to suit your preferences and save it so you never have to do it again
•Supports 1996 and newer passenger vehicles, whether it be domestic, Asian, or European.
SAE interfaces: J1850 (PWM and VPM), ISO-9141-2, ISO-14230 [KWP2000], and CAN [11bit and 29bit] with the addition of your chosen bundle.
Something we offer that the others don’t:
•True Plug-n-Play USB 2.0 interface
•Factory scan tool options available
All generic scan tools can only access the powertrain, no matter what SAE Modes (J1979/J2190) they use for communication. With our expansions, you can access dozens of systems (ABS, transmission, GEM, SRS/Airbags, Instrument Cluster, etc.) generic scan tools can't even see. This gives you access to thousands of sensors and dozens of bi-directional controls/system tests. Click here to see our enhanced support for Ford, GM, Chrysler Toyota, Mazda, Nissan, BMW, Land Rover, Honda, Subaru, Mitsubishi, Isuzu, Porsche, Mercedes, Hyundai/Kia, Jaguar , and Audi. Click here for complete enhanced option details.
•Optional enhanced expansions allow you to communicate with vehicles like the Powerstroke, Duramax, and Cummins diesels.
•Bi-directional support. You have the ability to initiate system and component tests
•Mode 6 support. If a system test fails, now you can see the results from the failing component; not just the system. Our Mode 6 data is fully translated so you don't have to waste hours looking the scale and definitions.
•Mode 9 support. Full ECM information including CAL, CVN, and VIN reporting
•Support for CAN and even the CAN 6x Mode
•Support for the new extended sensor list (233 sensors--supporting the SAE J1979 May 2007 additions)
•ALL the OBD-II vehicle interfaces in a single cable, rugged case. This is a savings of hundreds of dollars over the competitors' units
The ScanTool package consists of:
-AutoEnginuity's software
-AutoEnginuity's OBD-II vehicle interface (ST06)
-USB 2.0 interface and cable
-User Guide
-Quick Installation Guide
Old Dec 19, 2010 | 09:49 AM
driximus's Avatar
driximus
I know you can run alot of tests with AE, I can not tell you for certain if it is gonna help you with this specific problem. I personally have not used AE but I know I want it.
I would get a multimeter and just start chasing wires.
Old Dec 19, 2010 | 11:35 AM
armstrongfordtrucks
driximus, thanks. Just got the truck back in the garage, will start chasing the wires next weekend as I have to leave this afternoon for W.Va. for another week of work. Just glad I have a company truck for work or I would be in for a weeks vacation, being below 20 degrees next week.
Old Dec 19, 2010 | 01:40 PM
armstrongfordtrucks
Pulled the driver side valve cover connector and ohmed GP connector's, two each end. driver side, 1.2, .9, 1.3, .9.
Pulled the connector off the GPCM and probed two large wires and 12.6 volts.
Pulled the valve cover connector again and probed the two on each end of connector. 6.4 volts with key OFF !? Turn key off and all 4 have 12.6 volts. Why 6.4 with the key off ? Put it back together til next weekend. Leaving for work.
If I probe the battery it has 12.5 volts, turn the key on and it drops to 11.8 for about 1 1/2 minutes and then goes to 12.5 sitting in a 70* garage. Did the twice and the same both times. Do you think the GP"s are working.
Could it be there is no problem with the GP's.
It started with no problem after being pluged in for 1 1/2 hrs. It was 14* here this morning.
Thanks
bismic
Mar 9, 2022 09:20 AM
Papawheelie
30
Feb 23, 2017 05:14 AM
Biggoomba
1947 and Older Ford Trucks
41
Nov 27, 2013 07:07 PM
BaitGuru
May 12, 2010 11:14 AM
dditto
Nov 7, 2008 07:57 AM
