I called the local stealer to get some roll over valves for the tank mod and he said it must be obsolete because he showed nothing for the number. I used part #F4TZ-9B593-H from Jim's mod page. Anybody have a new number or know what that valve goes to? I'm using the search function but as always not having much luck.
Well that doesn't make me very happy. Now I've got a modded fill neck with no larger valve. I guess I'll use a pipe fitting if I have to but I like the idea of a roll over valve.
Does the Ford roll over valve fit into the existing grommet or do you have to widen the hole? I like the idea AND look of a single vent hose from fill neck to valve. Sure would like to just get the Ford part.(never thought I'd hear myself saying that)
Ok so I found the part# for the roll-over valve: F4TZ-9B593-G
It's still a good number. It has a 3/4" hose barb so at the filler neck, I used 1/2NPT x 3/4" hose barb straight fittings. Works perfectly and I'm guessing vents better with the bigger line than the 5/8" would.
You got it Chase! Except I put the 38gal tank in the dually, not the Bronco. Close though!!
Bought those not even a year ago at my local Ford dealership. Number is good. IT does use a 3/4" hose and not a 5/8" like Jim's did.
For the vent line, I went to a local farm/ranch supply store and bought a 15" roll of 3/4" diesel transfer tank line. Cut the ends off and cut to fit with extra left over. Was about the same price if not a tad less than large gas line was at NAPA. And it's specific to diesel.
Can fill up without issue now. Fill on the fastest setting till it clicks off. Then not much more is needed till it's too the top of the filler neck. I love it!!!
CRAP!! It is discontinued now. My dealer is out. They show a couple dealers waaay out of state to have for $41 so I'm gonna call and see how much shipping would be. Do yall think any of the SD tanks have the same size holes and bigger valves?
