Cab & Chassis do not come with any back of cab equipment (pickup beds) from the factory, just bare frame rails. Cab & Chassis are used to install aftermarket equipment like Utility, Flat, and Stake Beds (and etc).
Sorry to dig up this old thread, but ive been searching around for the roll over valve.
I tried Jim's number first (as most have) and then started searching. I tried all of the ones NumberDummy listed and that last one...E7DZ9B593A looks to be good still. I mean I found a bunch of links on google that said "no longer available" or "item listing ended" but i did find this link...VALVE ASY - FUEL VAPO. # E7DZ9B593A, E2AZ9B593A
It doesnt give much info on the page... lol I just want to be sure, but I will need this valve and whatever grommet to go with it..
Im doing the 38 gal tank like JR did..
Glad you dug this up. Does this kind of thing mean we need to update the sticky page to let people know you can't get the right valves anymore? Seems like if a part goes obsolete then the sticky kind of does too.
Nice find, tried to you know what and you know what happened!
you tryin to speak elf to me? lol
its like a guy who didnt know exactly what to say. "tried to... you know what.... and ...uhhh.. you know what happened?!"
I would like someone more knowledgeable to confirm that is the correct part, but yes if that is true and that one is available i say it should be updated.
I tried to 'rep' you and you know what happened (couldn't). LOL
I think that is a normal 1/4 valve but if you order one, let me know.
I am wanting to do the tank vent mod. and I found a tank vent kit from Glacier Diesel Power for the '03 to '12 Dodge trucks. You drill a hole in the fuel tank and install their bulkhead fitting and hose. Then you have to do the fuel filler neck mod. and connect their 3/4" hose to your modified fuel filler neck. Now you can keep the factory fuel tank vent.
