heated seats
Old Dec 16, 2010 | 08:54 PM
spotshot's Avatar
spotshot
heated seats
my 2000 expedition driver side seat heater stopped working. What is involved with replacing the heater?The switch lights up but no warm buns.
Old Dec 16, 2010 | 09:15 PM
c_hohensee's Avatar
c_hohensee
Have not had the problem myself, but from what I have heard there is a wire that breaks and can be repaired by taking the seat cover off. This is the most common thing it seems.
Old Dec 16, 2010 | 10:52 PM
spotshot's Avatar
spotshot
thanks I will take a look this week end
Old Dec 17, 2010 | 10:40 AM
Londart's Avatar
Londart
my wifes has the same problem...let me know what u find.....thanks
Old Dec 17, 2010 | 05:01 PM
thecardoc's Avatar
thecardoc
If the light comes on the problem can most likely be fixed for just your time . I had this problem on my 99 expy . Just pull the seat out then pull the cover off ( the bottom one is the one that usually fails). Once you get cover off you will see a burnt spot or maybe 2 where the wires are to short in the heating element in the back. I just added a little more length so it wont happen again. The element wires are very thin but workable . I soldered mine . You will need hog ring pliers and 8 to 10 hog rings . Once you get the cover off this will all be obvious . Good luck if you try this it took me about a hour and a half.
Old Dec 17, 2010 | 11:03 PM
moose_j9's Avatar
moose_j9
Quick question for you, Do you have side air bag on seat? If yes, did you simply disconnect and reconnect the SRS connecter under the seat or did something special?
Old Dec 17, 2010 | 11:39 PM
thecardoc's Avatar
thecardoc
Mine did not have side air bags . Be sure to follow safety guide lines about disconnecting battery before working on those air bags. Also I saw Rock Auto has replacement heater pads .
Old Dec 18, 2010 | 12:46 AM
moose_j9's Avatar
moose_j9
https://www.ford-trucks.com/forums/1...t-removal.html
the above link what i have posted few moments ago.. can you give me some advise on that... thanks
Old Dec 18, 2010 | 08:06 AM
Moto Mel's Avatar
Moto Mel
I asked a similar question some months ago and was told that there is no problem with just removing them. I only wanted to do a major carpet cleaning in mine but that's going to wait 'til spring now.
Old Dec 18, 2010 | 10:26 AM
moose_j9's Avatar
moose_j9
I was thinking the same thing. Once battery got disconnected. stored energy in SRS will be depleted shortly......so no power..no problem...
I will repairing the leather cover and check on heat seat at the same time..
Old Dec 18, 2010 | 12:16 PM
spotshot's Avatar
spotshot
Thanks for all the help
Curt's05
Escape & Escape Hybrid
Jan 5, 2014 08:55 AM
sig40
Jul 20, 2012 10:42 PM
jake00
Mar 7, 2011 10:50 PM
dcicc50
Jan 31, 2009 12:17 PM
drwhy
Jan 21, 2003 02:19 PM
