Tapping sound
Old Nov 19, 2010 | 10:03 AM
dewking's Avatar
dewking
Tapping sound
I developed this tapping sound from the engine it comes and goes sounds like a valve once the sound starts it dont stop untill its restarted, then will go for awile then start again, sometimes it doesnt do it at all. 1990 V6 any thoughts
Regards,
D
Old Nov 19, 2010 | 03:04 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Try to identify the cylinder by listening with a hollow metal tube or something like a dowel rod. Pull the plug and compare it to the ones next to it. Pull the valve cover and take a look. You may end up pulling the head to have a shop perform a valve job. I would recommend doing both heads if you have to get a valve job.
Old Nov 19, 2010 | 07:17 PM
g_k50's Avatar
g_k50
Bent valve? remove, rebuild and replace heads.
Old Nov 20, 2010 | 12:40 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
When I lived in Maine, my Buick V8 developed a tap from the last rocker arm to receive oil on a cold start up. That was with less then 25k miles on a new engine. The repair was a new rocker for the valve train and a valve cover gasket. Like the other posts, you will have to get in there and take a look once you locate which cylinder is tapping.
mattgilm
Jul 23, 2012 07:45 PM
dehamma
Nov 7, 2011 12:44 PM
Wayne U
Bronco II
Mar 13, 2011 10:40 PM
nrichlen
16
May 22, 2007 10:57 PM
tim73
Apr 27, 2003 07:41 PM
