New electrical problem...??
Old Dec 15, 2010 | 10:10 PM
Domestic_Nuwbee's Avatar
Domestic_Nuwbee
Hi guys,
I just installed two 6x9 w/ custom built box, in my truck yesterday. (pounds!! for 6x9) But when I turn it up, the lights on the deck dim everytime the bass knocks. Eventually....it led to my headlights flickering! Does anyone know what this could be from? I figured the 6x9 are drawing a lot of power from the deck (old) which may be causing this but I'm not sure. Oh!...and when it was on loud, the sound would cut out and come back on, sometimes just one speaker or both.
Thanks guys,
(90 F250 4x4 w/302 HO)
Old Dec 15, 2010 | 11:50 PM
CWPottenger's Avatar
CWPottenger
Definitely sounds like too much draw... running an amp?
Old Dec 16, 2010 | 05:04 AM
jplinville's Avatar
jplinville
Cutting out? You have either a loose connection, or a ground issue
Old Dec 16, 2010 | 08:37 AM
nstueve's Avatar
nstueve
sounds like it could be either to me. I would check the grounds first. Then I would have your alt and battery checked at the auto parts store. Keep in mind our old external fan alternators only put out 65 amps... when new... If you want to bouce that bass and add aftermarket stero equipment, it's usually best to do a 95-130amp 3G upgrade to make sure your not over drawing the entire system.
Old Dec 16, 2010 | 12:42 PM
SleeprLegend's Avatar
SleeprLegend
How did you connect your new speakers in the box to the stock radio?
Old Dec 17, 2010 | 02:21 AM
Domestic_Nuwbee
Put it this way, it only encounters a problem at high volume. Which i can logically presume the connections are solid and it is ground properly. Mind you, before I had the 6x9 in, I was just running the little 4" door panel speakers at high volume and no problems. Maybe just a tiiiiiiny little dimming of the lights on the deck. I mean... how much draw can little 4" speakers cause?? which led me to believe it might be the deck itself.
Old Dec 17, 2010 | 02:23 AM
Domestic_Nuwbee
No amp....just straight off the deck. Deck puts out 30watts x4 and the 6x9s are 85watts capacity.... maybe it lies there?
Old Dec 17, 2010 | 02:26 AM
Domestic_Nuwbee
INTERESTING! I love it when I come on here, i learn something new everytime. One would think so really it's messing with my electrical system. I was jus parked with truck running when my headlights started to flicker like a strobe light. I will look into this...
Thank you
Old Dec 17, 2010 | 02:30 AM
Domestic_Nuwbee
The 6x9 are wired to terminal speaker connection plate mounted on/in the boxes. Like any speaker terminal hook up behind a speaker, then wiring from the deck wired to designated spots.
forgot, it's aftermarket cd player. old school clarion deck...
Old Dec 17, 2010 | 02:33 AM
86F150302's Avatar
86F150302
Check your voltage. I don't even think its possible for a headunit to pull too much power. But maybe its just adding to a problem you already have.
Normally when the sound cuts out its an AMP going into protect mode from low voltage or a short.
Whats really throwing me off is that you have no amp at all. Just headunit power.
But anyways check your voltage with stereo on and off and see what you get.
BTW these trucks have 6.5" door speakers. Not 4"
Old Dec 17, 2010 | 02:49 AM
Domestic_Nuwbee
Holy S*** 6" in the doors!?! whoa, wouldnt think that honestly, that or mine just need to be replaced badly. My bad, thanks for the enlightment on that, wouldve never guessed.
yup no amp!...killer deck eh!? ahahaha. Ive hooked up many sound systems and speakers and have never come across this before, so kinda stumped.
I hate electrical as it can be caused/come from absolutely anything.
you guys still think it's worth ungrading to higher amp alternator?! what other advantages would I have from that aside from stereo?
Old Dec 19, 2010 | 02:25 AM
86F150302's Avatar
86F150302
Lol no. a headunit takes barley anything to run. I run a 200 amp alternator but that was for my 3500+ watts rms I was running with my amps.
If you were running alot of lights, electric fan, winch, or some nice amps then yes. But for what you are running you dont need to do anything to your electrical. Stock will be just fine. I ran 1000rms on stock alternator and battery okay.
Try a different deck and see if that fixes it. But like I said earlier you still should check your voltages.
Old Dec 19, 2010 | 11:34 AM
Domestic_Nuwbee
New deck is going in pretty soon here, so hopefully that's what the problem is. I'm pretty sure it is...
Checking my voltage as simple as putting a voltage meter to the fuse panel?
Old Dec 19, 2010 | 02:27 PM
jplinville's Avatar
jplinville
Did you check for a short in the speaker wiring?
Old Dec 19, 2010 | 03:40 PM
Domestic_Nuwbee
Yeah, i went over everything and it is all good solid contact.
BLADE35
1983 - 2012 Ranger & B-Series
Aug 26, 2013 09:17 PM
nitrain03
Jan 3, 2012 10:18 PM
Domestic_Nuwbee
16
Dec 27, 2010 03:43 AM
Domestic_Nuwbee
Aug 4, 2010 10:03 AM
Eddie250
Apr 21, 2009 02:27 AM
