Dome light wiring question
Old Dec 15, 2010 | 03:56 PM
mr_ranger-79's Avatar
mr_ranger-79
I have a 1979 F-250 4x4 XLT. My dome light has never worked. I have replaced the light bulb, light switch, and the door switches. The dome light will not come on with the doors or by the switch. I also turned the light switch **** all the way to the left where it clicks to turn on the light and put a test light on each of the terminals because I thought that one of them should light when that switch clicks...am I right on that or not? Does anyone have any advice or ideas where I should look next? I would love to have this light working! Thanks in advance...
Old Dec 15, 2010 | 06:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Since you checked for voltage at the socket and didn't get anything its time to trace the wire back to the harness and make sure there isn't any damage and that its connected to the main wiring harness.
Old Dec 15, 2010 | 07:04 PM
southernboy0122's Avatar
southernboy0122
Deleted........
Old Dec 15, 2010 | 07:05 PM
southernboy0122
Have you checked to see if you have power at the fuse block?
Old Dec 15, 2010 | 08:08 PM
steponit's Avatar
steponit
If not the fuse...#7
Chances are the connector came off behind the instrument cluster.
Old Dec 15, 2010 | 11:17 PM
mr_ranger-79
Thanks to all for your replies...now I have something to do tomorrow...LOL
