37" Hummer tires
I like to have a set around to use as a street tire or long distance trip tire to save my more aggressive treads. I think they're a step above an all-terrain in offroad use. In the past, I've gotten 40k out of a set that started with 75-80%. I think they're an awesome tire to keep around just in case, especially considering the price.
Thats exactly the reason why I'd like to have a set. Also now that its getting colder we take the 40" off since they flat spot easy and thats annoying. I have a set of steel wheels that I believe are the factory width which have 9.50-16.5 on them now. I want to put those 37x12.50's on them but I'm not really sure how wide my steel rims are. Any ideas?
To narrow a rim will round the side walls and give a real bad wear pattern, especially on the front end. As far as a 16.5 rim you will be ok as long as you do not air down much and wheel to hard.
But it sounds like they will be a winter only set up, so you should be ok. And for the price, 90% tread @ $200 ish for 4 right? You can't beat the price IMO.
The radial 37's are alot better than the bias ply 36's, again IMO.
5 MILITARY TIRES 37/12.50-16.5 HUMMER HUMVEE HMMWV - eBay (item 110579937524 end time Dec-28-10 03:43:44 PST)
These are way nice than ones I found earlier and have the freight factored in. I think it would be hard to beat this price.
100Dollarman - Tires!
