Adjustable fuel pressure regulator?
Old Dec 15, 2010 | 09:47 AM
hav24wheel's Avatar
hav24wheel
Is there one available for a 5.8? I've found them for the 5.0 but doesn't look like it will fit on the 5.8. Or am I going to have to make the 5.0 fuel rails fit my 5.8? I need to up the fuel pressure to richen up the fuel ratio.
Old Dec 15, 2010 | 10:28 AM
Conanski's Avatar
Conanski
Both motors use the same regulator but there are 2-bolt and 3-bolt versions depending upon the year, earlier motors used a 3-bolt reg while the later motors were 2-bolt.
But be aware this may not be the simple fix you think it is, the computer will immediately counteract increased fuel pressure by reducing injector duty cycle while operating in closed loop.. which is most of the time. So the increased fuel pressure will only richen the fuel map when the motor is running open loop, but that's when you need it anyway.
Old Dec 15, 2010 | 10:32 AM
hav24wheel's Avatar
hav24wheel
Well heres the issue, the plugs are showing a lean condition, and I can't figure any other way to richen it up....
Old Dec 15, 2010 | 10:34 AM
Conanski's Avatar
Conanski
Your truck is factory MAF or converted?
Old Dec 15, 2010 | 10:37 AM
hav24wheel's Avatar
hav24wheel
Factory 5.0 MAF, swapped in a 5.8, running the stock 5.0 computer and electronics, with 21 lb injectors.
Soon going to be swapping in a 89-93 mustang computer..
Old Dec 15, 2010 | 10:39 AM
Conanski's Avatar
Conanski
Ahhh. 21lb injectors is your problem.
Old Dec 15, 2010 | 10:42 AM
hav24wheel's Avatar
hav24wheel
how is that the issue?
http://www.summitracing.com/parts/AC...e%7c5.8L%2f351
Old Dec 15, 2010 | 10:49 AM
Conanski's Avatar
Conanski
It is the issue because the computer is programmed for 19lb injectors.
Old Dec 15, 2010 | 10:51 AM
hav24wheel's Avatar
hav24wheel
But the 5.0 all stock did the same thing...
I put a new fuel filter, MAF, O2, and TPS on with the new motor too...
Old Dec 15, 2010 | 11:04 AM
Conanski's Avatar
Conanski
These motors do run pretty lean, are you having detonation(pinging) problems?
Old Dec 15, 2010 | 11:10 AM
hav24wheel's Avatar
hav24wheel
Yep. Had timming set to 14. Dropped it to 12. Haven't pulled a heavy load yet to see if its still pinging. Have upgraded coil and wires. Plug gap opened a bit.
Old Dec 15, 2010 | 11:12 AM
hav24wheel's Avatar
hav24wheel
Would I need a different Spout connector for the 5.8? I have a gray one in there.
Old Dec 15, 2010 | 02:29 PM
hav24wheel's Avatar
hav24wheel
BBK Performance 1706 - BBK Billet Aluminum Adjustable Fuel Regulators - Overview - SummitRacing.com
Ordered... mine is a 3 screw type..
Old Dec 15, 2010 | 03:19 PM
Conanski's Avatar
Conanski
The spout is just a jumper plug so color doesn't matter.
Did you have the 21's on the 5.0 too?
Old Dec 15, 2010 | 03:36 PM
hav24wheel's Avatar
hav24wheel
Nope had the stock 19s on the 5.0.
