Adjustable fuel pressure regulator?
Old Dec 15, 2010 | 05:08 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Sounds to me like you need to get a wideband O2 on there and get some custom tuning on it.. Maybe Tweecer?
Old Dec 15, 2010 | 05:25 PM
lew52's Avatar
lew52
X 2 , you need a wide band on it so you can see what your FP ratio is , it will never run right with the stock air meter and bigger injectors , you can have the meter calibrated , but a custom tune is best .....
Old Dec 15, 2010 | 05:29 PM
hav24wheel's Avatar
hav24wheel
When I get the A9L computer put in it I should have more options to play with the tune right?
Old Dec 15, 2010 | 05:39 PM
lew52's Avatar
lew52
Your going to have to get in to the computer and change some things , the air meter needs to be matched to the fuel injectors , the AL9 is still set for 19# injectors...
Old Dec 15, 2010 | 06:28 PM
my91stealth's Avatar
my91stealth
if he changes his maf to one thats calibrated for the 21's he should'nt have to do anything to the computer.atleast thats with the mustang motors.
Old Dec 15, 2010 | 06:29 PM
strokin'_tatsch
The MAF doesn't need to be calibrated to the injectors, just the PCM does. So a chip will take care of the bigger injectors. Calibrating the MAF isn't technically correct... The best way to do it is through the computer...
Old Dec 15, 2010 | 06:56 PM
lew52's Avatar
lew52
You can have it recalibrated , but i agree with Travis , you will get alot more with a computer tune ....
Old Dec 15, 2010 | 07:01 PM
my91stealth
I've just heard it done just buy swapping the maf
Old Dec 15, 2010 | 07:13 PM
lew52's Avatar
lew52
....It can be done that way , i have a 302 with 30# injectors , i have a pro m 80mm mass air meter that was tuned for the truck and the injectors , it ran fine with the stock computer , but after a dyno burned chip it is much better....Lew
Old Dec 16, 2010 | 12:24 AM
hav24wheel's Avatar
hav24wheel
Ok, so basically, I'm not going to worry about it tell I get the other computer installed. Than I'll look into a chip n leave the MAF alone.
ybshore
Mar 22, 2017 02:27 PM
tbick
Mar 13, 2017 04:08 PM
fordboy97
Oct 21, 2015 08:42 PM
50monte
Oct 14, 2015 12:47 AM
tygarcia
1978 - 1996 Big Bronco
Jan 14, 2010 10:34 AM
