looks like another keyless thread lol
Old Dec 14, 2010 | 06:26 PM
Hitokori's Avatar
Hitokori
today i bought and installed the bulldog keyless ke1702 system
install was simple
my question is with the parking light confirmation
the keyless module gives a (-) negative ground when the doors are locked or unlocked... it does this to the brown wire for the parking lights...
anyways if that made sense then my question is do i need the 775 relay or do i tie it into the parking light wires...
the truck i installed this in is a 1988 f150 xlt lariat
with factory power locks and power windows
Old Dec 14, 2010 | 07:05 PM
Franklin2's Avatar
Franklin2
Your parking lights definitely are not going to turn on if you ground them. I suspect you need the relay, ground it, and let it send power to the brown wire.
Old Dec 14, 2010 | 08:02 PM
Hitokori's Avatar
Hitokori
k thanks thats what i was thinking but i just wasnt 100% more like 90% lol
ill grab the relay tomorrow hell its only $7
i have and extra one laying around from my e fan install but idk if i can use it for that or not...
i havent wired many relays for this purpose...
http://www.bulldogsecurity.com/bdnew...me%20Light.pdf
hope that link works... the relay i have doesnt have a center prong on it... the one they have numbered as 87a
but i have one that has 30 86 87 85
and on their diagram it shows the yellow for the parking lights going to a (+) positive and the dome lights yellow going to a ground... would i hook it up as a positive or a ground? im not doing the dome light part...
and do i have to do the 1 amp diode?
idk... ill go look at the relay they sell lol maybe it will have the diode and everything else coz i dont have a soldering iron or wire solder here
Old Dec 14, 2010 | 08:28 PM
Hitokori's Avatar
Hitokori
actually i got to looking at this e-fan relay kit and it has a diode on the harness for it where it ties into the a/c lol
its a IN4005 1 amp 600v but its on a 20 gauge wire
Old Dec 14, 2010 | 09:42 PM
Franklin2's Avatar
Franklin2
I am thinking you would not need a diode if you only use one relay, but I am not sure so just put one in anyway.
You don't need the 85a terminal. They don't use it, and you don't need it either.
Basically they are hooking a hot wire to the coil terminal 85. But the relay does not kick on till the security unit grounds the other coil wire which is 86. This makes the relay "click" and connects terminals 87 and 30 together. Of course when you do this, you are putting the hot wire onto the brown parking light wire.
Old Dec 14, 2010 | 09:54 PM
Hitokori's Avatar
Hitokori
ok so ive re wired the relay i have lol
im slightly confused about the yellow wire in the diagram but im gunna tie it into the black wire on 85 and hope for the best lol thanks for the help ll reply tomorrow when i get it all hooked up and let you know how it worked out for me
thanks a bunch
Old Dec 15, 2010 | 10:59 AM
Hitokori's Avatar
Hitokori
well i bought another relay for flasher that has the 87a prong
but it still doesnt work... so im assuming i need to ground the yellow wire in the diagram... worst thing happen i fry the relay
tjc transport
Dec 3, 2010 06:59 PM
boulderbronco
6.4L Power Stroke Diesel
Oct 16, 2008 10:00 PM
boulderbronco
Oct 15, 2008 06:29 PM
01f350
Apr 13, 2006 11:02 AM
